Old 01-19-2020, 02:52 PM   #1
Is this a semi float rear axle?
Can anyone easily tell by looking at this photo if this van has a semi-float or full-float rear axle? It’s a 2010 E-350 pass van with a V10.
thejm is offline   Reply With Quote
Old 01-19-2020, 02:53 PM   #2
Rear wheel:
Old 01-19-2020, 02:55 PM   #3
Front wheel:
Old 01-19-2020, 03:24 PM   #4
You can't tell without taking a rear hubcap off. I believe all E350's after about 05 are FF axles
Old 01-19-2020, 05:43 PM   #5
Actually it's the other way around.
2011 VW TDI Golf for hwy fun
Old 01-19-2020, 06:53 PM   #6
1der's Avatar
As mentioned, need to pull the hub cap to determine if it is a FF or SF.
Re: determining FF by model/year, etc. - good luck. Ford often states that a particular model came with a FF as a stock specification. That is often enough not the case in reality.
Unless someone showed me the actual OEM VIN build sheet for the van, or a picture with the hub visible, I would not put any confidence in knowing what rear axle was present.
Old 01-19-2020, 07:41 PM   #7
Thanks everyone. Going to look at it tomorrow I will find out soon enough!
Old 01-19-2020, 10:22 PM   #8
bigriver's Avatar
If it sticks out like this it is a full float
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
