Old 03-04-2012, 01:16 PM   #21
Nomadcat's Avatar
Re: mpg help!
This thread is a good reminder to me to get that piece of plexiglas I have been meaning to buy and angle from the roof to the top of the roof rack, facing frontwards.
EDIT
I am actually going to call Aluminess tomorrow and see if they make or will fab something like this:
http://www.quadratec.com/products/92026 ... 4AodCHg3AA
One day at a time
Old 03-04-2012, 03:31 PM   #22
Re: mpg help!
EDIT
Could you start with an experiment, something like a couple of gutter mounts on the forward metal van roof, a crossbar, and a deflector like that mounted to the crossbar?
Likely much cheaper, and could be resold relatively easily if it doesn't work out, or if it works but you'd prefer a more solid, integrated solution that Aluminess would likely come up with.
Old 03-04-2012, 05:16 PM   #23
Nomadcat's Avatar
Re: mpg help!
Hi Herb.
I was just down there a while ago, taking measurements.
Yes, the mounting is the issue. I guess I'll have to wait until tomorrow and go back when it's daylight and mull on it.
I wanted something low profile. Gutter mounts might be too obtrusive. My solar panel, which is mounted at the front of my roof rack, also presents a slight problem. Like I said, I was there, but just for a little bit. I need to go and study this a bit.
I'd like to come up with something that's non invasive, low-profile, and inexpensive.
Paul
One day at a time
Old 03-04-2012, 07:53 PM   #24
BajaSportsmobile's Avatar
Re: mpg help!
Duct tape and cardboard to test - doubt you will see much improvement, but worth a try.
AgileOffRoad.com
Old 03-04-2012, 09:55 PM   #25
Re: mpg help!
yeah, I want to do that too.. my rack is set back a couple feet from the front of the van and the sides angle down to the front for wind but I can here the expanded metal "howling" in the wind so some plexi might be next. also might try the Fitch fuel catalyst. they did a test on HPTV and it did quite well.
racrx451 is offline   Reply With Quote
Turtle
rafeman
Vanna
gahamby
