Originally Posted by Roonie
Originally Posted by Chimneyman
im running power stop rotors and pads and i also had them HEAT TREAT & CRYO. 200% better brakes i can lock up 35" tires when my v an is loaded. its worth the money. I have these same rotor on my E350 Service van and i was putting brakes on every 6 months rotors to. scene I Put the Drilled Cryo rotors and there ceramic pads no problems. for over 1 year I have these on ever 4x4 I own. So i don't know what brand rotors you are using. But buy putting mine on its saved me thousands of dollars. of the cost of new brakes every 6 months and my service van down for a day.
What is the cost for rotors and pads heat treated and cryo? I see they have the extreme duty towing and heavy vehicle pad as well. Cost of both items?
Anyone else have any experience with this company? I wonder how they compare to Brakeman which is recommended by SMB? Brakeman run about $900 for 4 rotors and pads for the SMB.
I had SMB do the brakeman upgrade about 12 months ago, after driving 4 years with the stock setup.
There is a noticeable difference in stopping power. But it is very modest and does not change how I need to drive the SMB. I retains all of the handling/braking characteristics you'd expect from a 10k pound truck. I doubt that any brake upgrade will change the physics of an SMB.
Both SMB and brakeman told me that the key advantage of the upgrade was resistance to brake fade, not improved stopping power. I've found this to be true and have 'tested' the new setup on some pretty hairy descents. So basically, I don't assume I can stop any faster, but am far more confident that the brakes will be there if/when I need them.
R
