Old 10-05-2017, 05:47 PM   #1
Location: On an island in the Western basin of lake Erie Ohio
Question about a full floating rear axle.
I have the chance to pick up a full floating rear axle from a 1992 ford E350 van. It is a "32" which turns out to be " Dana 6250lbs. 4.10 Econoline.
My van is a Quigley rig 1990 E250 with a dana front end Model 044BA526-9 Serial # 22090. It has a ring and pinion of 3.73
What would I have to change to put the full floater on my van? I am confused if I need to change the transfer case gearing or front Ring and pinion.
Any and all help will be appreciated. Thanks in advance.
I would like lower gearing as I have overdrive and a 351 Windsor engine. It is very underpowered and I do not have the need to speed.
QuigRig is offline   Reply With Quote
Old 10-05-2017, 06:07 PM   #2
wadewaydo's Avatar
Yeah, the gearing in the front and rear have to match, not the transfer case.
1995 Econoline E-150 Custom Campmobile "Jupiter I" RB, 4wd Dana 60s, 93 Eurovan poptop.
1976 VW Type II Transporter Westfalia Campmobile.
1994 Toyota 4Runner,2001 Ford Escape,1970 Chevy El Camino,2 Cargo Trailers, 5 bikes, 4 Kayaks, 1 Canoe
wadewaydo is offline   Reply With Quote
Old 10-05-2017, 06:12 PM   #3
Thanks, Wadewaydo. I was thinking that but researching I came across something about the transfer case also.
I had a 78 Westy for years and an 82 Westy 1.6TD now. Love them both.
Thanks again. More research.
Old 10-06-2017, 09:04 AM   #4
bet on black's Avatar
change the front gears to match the rear. that's all you need to do.
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Bruce
Sboring35
Zengi
Amy V
