Old 08-31-2009, 12:23 PM   #11
reidt's Avatar
Re: Rear Differential/Transmission/Driveshaft noises?
To all who wrote back on this one...
It is my muffler! the baffles are deteriorating and alas the perfect harmonic convergence is the annoying noise I am hearing. waiting it out until I fully need a new muffler.
Thanks for the post.
Reid
Reid
'99 RB 50, V10, 4WD
reidt is offline   Reply With Quote
Old 08-31-2009, 12:37 PM   #12
On my last trip, my house battery got very low and since it was hot and I really needed to keep the fridge on all night I put the Diesel on high-idle for an hour and lay down in the back to read a book. The engine was making this awful noise, a loud vibration that I never heard on the road or other times I'd idled to charge. I was convinced it was a harbinger of engine problems but I had to charge the batteries so I continued to let it run.
Two days later I noticed the same noise at a rest area. The van was off, and I thought a really loud semi must have pulled up. I sat up and turned off the fridge to listen and ... the sound went away. It was the danged Norcold... it has started to resonate in the back of the van and is actually louder than the diesel when I'm in the bed. Awful.
Glad you found the problem.
Old 08-31-2009, 04:56 PM   #13
deminimis's Avatar
Jage, as you know, there is a cure for a noisy Norcold. Do you need to borrow my Sawzall?
Old 08-31-2009, 08:29 PM   #14
No, but could you spare the $1500? I'll gladly pay you Tuesday.
Old 10-25-2009, 09:47 AM   #15
SierraHawk's Avatar
What I have found is that either something in the fridge door is vibrating and the noise is somehow amplified by the door or something in the drawer above the fridge is vibrating.
SierraHawk is offline   Reply With Quote
