Old 07-17-2012, 08:33 PM   #11
BIGVANS's Avatar
Re: The Full Badger
Nice work on all those vents! Especially the fender vents! Looks like you took your time and did it right as far as we can see.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 07-23-2012, 04:43 PM   #12
etbadger's Avatar
Re: The Full Badger
I've always been told "You never go full Badger!"
(looks nice, when parked for a while under trees in fall/spring I throw a tarp over our hood to keep out leaves & flowers/pollen)
-e
https://www.badgertrek.com - Badgers on Wheels
etbadger is offline   Reply With Quote
Old 08-05-2012, 06:56 PM   #13
UJOINT's Avatar
Re: The Full Badger
We just installed a set on MegAmbo and it's amazing how much heat escapes thru the vents. The owner claims less noise and lower temps too.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 08-05-2012, 09:46 PM   #14
Re: The Full Badger
same vents? pics?
Old 08-06-2012, 07:06 PM   #15
Re: The Full Badger
What's a MegAmbo?
2008 6.0 PSD with Advanced 4x4 conversion
I love gas vans too!
IheartDieselVans is offline   Reply With Quote
Old 08-06-2012, 09:23 PM   #16
BIGVANS's Avatar
Re: The Full Badger
Originally Posted by IheartDieselVans
What's a MegAmbo?
Check U-Jiont's threads here -
Expedition Portal forum
http://www.expeditionportal.com/forum/t ... ead/page10
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
