Originally Posted by deserteagle56
I wish there were a way to fix that!
Why not just tap the Tow/Haul button one more time? You don't have to use if you don't like it.
Since the 4R100 doesn't have Tow/Haul, the only way to up shift pressure and change shift point is with programing (I use the Predator). This is certainly an option for the TorqueShift as well. I Highly recommend looking into a 5-Star tuner. He does nice things for the V10, and can make it shift however you want (actually, come to think if it the 5-star will disable OD in tow/haul if so desired).
