Old 02-16-2017, 07:47 PM   #11
Hi Scott,
I always try to refill my propane tank when it is down around 1/4 full. I don't think there are any issues with letting it get empty though.
I put this thermostat in mine. It is battery operated and works great.
Honeywell TH1100DV1000 Pro-Digital 2-Wire Heat Only
$30 on Amazon.
Jeff
2010 V10 EB45 4X4
new2tx is offline   Reply With Quote
Old 02-17-2017, 06:53 AM   #12
Pntyrmvr's Avatar
Letting the tank run down to atmospheric pressure risks air entering the tank. This can get bad enough to interfere with combustion. Purging the tank is the next step.
The best bet is to close the valve immediately on running out and filling it right back up with propane.
Old 02-17-2017, 12:22 PM   #13
We were smelling these whiffs while the van was parked in the driveway with everything shut down, LP valves closed, and cold for days.
Makalu1 is offline   Reply With Quote
Old 02-17-2017, 08:39 PM   #14
pugslyyy's Avatar
If you can smell propane inside the rig, that's important. Outside, not so much. Use a spray bottle to check all the fittings, but it could also be vents / pressure relief valves / the regulator.
pugslyyy is offline   Reply With Quote
Old 02-18-2017, 05:37 AM   #15
E-rex's Avatar
Originally Posted by Makalu1 View Post
We were smelling these whiffs ...with everything shut down, LP valves closed, and cold for days.
Assuming you mean the main valve at the tank. Seems unlikely that what you were smelling was coming from the main tank- probably some residual propane still out in the system. If you wanted to confirm this, you could close the main valve to stop any new propane going into the system. Then open everything (outdoors, in a safe manner) and release any remaining gas in the system past the tank. I would bet that you would not smell anything after that under the typical circumstances (cold temps, etc).
'08 E-150, std roof, wb, 2wd - basic cleanup done. Working on rough layout of 'furniture'.
Pretty much everyone will step on their 'willy' once in a while.
I usually make it a point to stop and put on my golf shoes first..
E-rex is offline   Reply With Quote
