Old 06-12-2013, 03:23 PM   #1
Draining water tank 2003 EB50
Hello all. I just bought a beautiful 2003, 7.3l EB50 with 59,000 well cared for miles and am getting to know my SMB. My water tank is mounted under the couch and I am wondering if the only way to drain the tank is by opening the small stop cock in front of the tank, near the floor. It seems to drain very slowly. Is there a faster way? Any other suggestions? Thanks in advance. Fernando
"Not all Those Who Wander are Lost"
2003 Ford SMB EB-50, 7.3L 4x4, "La Mulita Blanca"
2006 Land Rover LR3 SE/HD
2010 BMW GSA 30th
medicfernando is offline   Reply With Quote
Old 06-12-2013, 04:59 PM   #2
llamadave's Avatar
Re: Draining water tank 2003 EB50
Congratulations on the new SMB!
You can run the pump and open a faucet to put it down the drain. This will be much faster. Just stand by and turn off the pump as soon as air comes out. You may want to open the dump valve for your gray tank. Let us know if you have more questions.
David
Savanna 2020 Sprinter EB 3500XD 4x4 lithium
llamadave is offline   Reply With Quote
Old 06-12-2013, 05:10 PM   #3
Thanks David. I appreciate the advice. We love the new rig and are itching to use it.
2010 BMW GSA 30th
Old 06-12-2013, 09:59 PM   #4
llamadave's Avatar
Not sure where you are located, but we would love to have you join us for the SMB meet and greet in Jackson hole June 21-32: http://www.sportsmobileforum.com/vie...p?f=11&t=10317
David
Old 06-17-2013, 10:26 PM   #5
Thanks David. We are in Salt Lake and would love to come up, but I am a firefighter and am on duty that weekend. I will be watching for the next one for sure. Thanks again
2010 BMW GSA 30th
Old 06-18-2013, 07:15 AM   #6
On my Ford the drain tube was pressed up against a frame crossmember from the top- basically drilled through floor, inserted pex until it stopped, which pretty much blocked the flow. I marked it and swiss-cheesed the section below the floor to increase drain flow. Alternatively you could cut the end at 45º or something, but I felt like dirt/clogging and bugs would be less likely with lots of tiny holes.
Of course I was taking everything out anyway at the time, so it was an easy tweak.
