Old 12-15-2013, 01:52 PM   #1
Easy way to fill fresh water tank from inside
The city water connection is always easier, but what if you want to fill your fresh water tank using the "manual" fill port from inside the van? Stick a funnel in there and spill water all over? Screw that.
http://morebeer.com/products/easy-siphon-38-inch.html
set a bucket or jug up on the counter and let gravity do the work!
(don't mind the towel, that was there just in case...)
This works for filling up the tank with pre-diluted sanitizer too.
BogusBlake is offline   Reply With Quote
Old 12-15-2013, 03:00 PM   #2
Jeffrey's Avatar
Re: Easy way to fill fresh water tank from inside
Been doing that for years. That's how I get the H2O from my jerry can into the house tank. Works great!
Old 12-15-2013, 03:04 PM   #3
Tapatio's Avatar
I added an external pump.
http://www.sportsmobileforum.com/vie...94&hilit=+Pump
Callsign KK6GIY
Old 12-16-2013, 08:17 AM   #4
llamadave's Avatar
My system has a 3-way valve on the inlet of the main pump. This switches the inlet from the bottom of the tank to a long tube. The ball valve above the pump switches the outlet of the pump to the top of the tank (many SMB probably already have this valve to fill the tank from the outside city water inlet). I use this tube both for filling the tank from a bucket and for pumping pink liquid when winterizing. The tube is long enough to have the bucket behind the van or inside the van.
Savanna 2020 Sprinter EB 3500XD 4x4 lithium
llamadave is offline   Reply With Quote
Old 12-16-2013, 09:22 AM   #5
Yeah, a 3-way valve on the pump inlet is already on my schematic for when I eventually reconfigure my water system. Llamadave, looks like you have a tempering valve in there too; that's also on my list.
I knew I wouldn't be the only one using a siphon to fill that tank. I actually LOL'd when I read the SMB manual and it showed a cartoon of a beer bong type thing for filling from inside. Maybe if you're dumping in a quart at a time...
Old 12-16-2013, 10:25 AM   #6
I deleted my post after realizing you must be talking about filling where a hose and spigot are not available. Llahma Dave makes my head hurt in a good way.
stanw909 is offline   Reply With Quote
Old 12-16-2013, 01:15 PM   #7
yvrr's Avatar
I did something similar but I didn't want to need to remove the jerry cans from the rear bumper holder:
http://www.sportsmobileforum.com/vie...filler+pump...
Jack
'01 Ford EB50p Quigley 4WD
Old 12-16-2013, 01:53 PM   #8
Tapatio's Avatar
That is really slick! How did I miss that post Jack?
Callsign KK6GIY
Old 12-16-2013, 02:05 PM   #9
ANZAC's Avatar
That is awesome!!
Of course all his has got me wondering, is there a way to do this by temporarily replumbing the existing pump....
Sportsmobile-less.
Old 12-16-2013, 02:19 PM   #10
That is a great idea. Too bad there's not another, lower water-tank fitting that you could then use to pump out the water from the tank by reversing the pump. The gravity drain always seemed to take forever on my SMB.
