Old 05-28-2010, 06:55 AM   #1
Shower Head Leak - HELP
Ok, so I haven't taken it apart yet, but I'm doing so this weekend. My exterior shower wand head leaks quite a bit when the water pump is on. I've tightened the hot/cold valves and ensured the button wasn't stuck. Anything specific to look for?
Thanks,
Jeff
2006 Red RB50 with SMB 4x4, 6.0 Diesel, PH Top, etc.
zaralps is offline   Reply With Quote
Old 05-28-2010, 07:48 AM   #2
scatter's Avatar
Re: Shower Head Leak - HELP
I had the same problem. There's a post here on the fix. You have to take the valves apart, but pretty easy.
Scatter
2007 RB50, 6.0
K1WGB
Old 05-29-2010, 06:14 AM   #3
Kind of buried but:
viewtopic.php?p=24052#p24052
Old 05-29-2010, 07:08 PM   #4
Jeremiah,
I cleaned it out and adjusted the seal...seems to be working! Of course I found another leak in my city water hookup...it was cracked. I ordered the part from a local store and should be here Thursday. Hopefully after that, I'll be done with the leaks!
Campervan
Joerg
My Van
bfolens
