Old 10-10-2017, 05:50 PM   #1
Side Door Lift Off Hinge For Cabinet - Ford E350
Anyone know if there is a good replacement for the side door lift off hinge that is normally welded to the side cabinet with the other bolted to the door. I bought my sportsmobile used and the original owner removed it cause he had damaged the table. Looking to build my own side table to replace it, but not sure what hinges are a good replacement. I called all of the sportsmobile shops, but they didnt have any advice. Sorry if this is in the wrong thread. Thanks!
RingTheAlarm is offline   Reply With Quote
Old 10-10-2017, 06:47 PM   #2
Inboard/outboard motor box hinge
hogasm is offline   Reply With Quote
Old 10-12-2017, 09:16 AM   #3
Thanks hogasm. I have the original hinge that is bolted to the door but not the hinge that is typically welded to the side cabinet. I was hoping to find a direct replacement so I didn't have to redrill the door. Maybe they don't make the part anymore.
Old 10-12-2017, 11:44 AM   #4
Got a photo?
Old 10-12-2017, 11:58 AM   #5
Originally Posted by arctictraveller View Post
Got a photo?
Thanks for trying to help. Picture attached. The hinges are the two lift off ones on the left hand side of th door. Trying to find the “female” parts.
Old 10-12-2017, 01:09 PM   #6
Lift-off Hinges - Loose Joint Hinges | HardwareSource.com
https://www.amazon.com/Slip-Joint-Li...&node=16412651
https://www.grainger.com/category/li...catalog/N-12ye
https://www.mcmaster.com/#lift-off-hinges/=19s7f7p
Old 10-12-2017, 01:40 PM   #7
https://www.mcmaster.com/#lift-off-hinges/=19s7spr
Old 10-12-2017, 02:08 PM   #8
Otter's Avatar
Perhaps I'm mistaken (I can't quite see all of the door in your photo), but that hardware looks like it's made to fit into matching holes in the cabinet, as in hanging from them. It's looks like there's four of them, all pointed upward, and the weight of a cabinet would likely keep it from going anywhere. In that case, no "female" parts needed, though maybe reinforcement around the opening?
Old 10-12-2017, 02:49 PM   #9
Since I have never seen the original cabinet I am going by what Sportsmobile told me and from some pictures i found on the web. SMB indicated the "female" hinge is connect to the cabinet. The female part slides over the male hinge that is currently bolted to the door and a latch on the opposite side (missing in the picture) locks it in place. They designed it this way so it could be removed if desired or swing out for access to the storage behind the cabinet.
Maybe someone that has the side door cabinet could provide a close-up picture of their hinge configuration to help out. It would be appreciate.
Old 10-12-2017, 02:50 PM   #10
Thanks for the links...it looks like the SMB hinge is offset from the door. Will the ones in your links work with the offset...meaning will it allow the cabinet to sit flush against the door like it does straight from the factory?
