Old 05-31-2013, 03:52 PM   #11
Viejo's Avatar
Re: StarCool A/C in high humidity?
If it runs off shore power, would a Honda 2000w generator also work to keep these running?
Probably not. The Honda 2000 can put out about 1.6 or 1.7 KW continuous. The AC probably draws more.
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 05-31-2013, 09:22 PM   #12
Viejo is correct and according to SMB you really need about a 3KW generator.
Old 06-03-2013, 04:14 PM   #13
Thanks you. Appreciate the info.
yogiyoda is offline   Reply With Quote
Old 07-07-2013, 10:49 PM   #14
2much8ntenough's Avatar
Send a message via Yahoo to 2much8ntenough
Originally Posted by yogiyoda
Will the older StarCool A/Cs plugged into shore power work okay in the stifling heat and humidity that is summer in Central Florida or will I need to get a model with ceiling AC?
Looks like you got your question answered, but wanted to confirm as we camp in Florida regularly. We’re using the Starcool III on shore power only. It works reasonably well during the day with the top dropped and windows covered; well enough to nap, etc. It will freeze us out at night.
Resurrected 2002 E-350 EB Quigley 4WD SMB
2003 Kawasaki KLR 650
2much8ntenough is offline   Reply With Quote
