Old 05-19-2013, 08:32 PM   #31
BrianW's Avatar
Re: Starcool - should I even bother fixing it?
I'm currently in the same boat and am troubleshooting my Starcool. Works fine on 12v with the engine, but when plugged into 110v AC it runs for about 5-6 minutes then trips the small 40amp breaker on the Starcool fuse panel inside. The weird thing is that it works fine for those 5 or so minutes; the AC compressor runs, it blows cold air, etc. Then "click" and it shuts off and I have to push the little button on the breaker to reset.
I replaced all the parts in the electric box attached to the AC compressor outside. New 110 and 12v relays, and a new capacitor. I also added a "hard start" Supco capacitor to give it some extra juice. So all those electronics are new. I can't figure out what's going on. I'm supposed to get a call back tomorrow from the Starcool expert at SMB Indiana. I'll see if he can give me any more ideas.
If/when I figure it out I'll post a postmortem in a new thread to help others. I also have part numbers for the new relay and capacitor for the 110v system. Got them at my local refrigeration parts dealer.
Old 05-19-2013, 08:43 PM   #32
Some circumstances a couple of years ago toasted my 110vAC Starcool compressor. SMBW replaced it. I don't know where they got it though. It works fine but still has the design problem of stealing power from my house batteries
Old 07-31-2013, 06:07 PM   #33
ANZAC's Avatar
How about this + a 110V->12v 20A supply to run it, connecting to the existing Starcool evap, and not connected to the vehicle AC:
http://www.proairllc.com/industries/amb ... uct_id=219
Sportsmobile-less.
Old 07-31-2013, 08:01 PM   #34
mmocken's Avatar
Send a message via AIM to mmocken
Any loose or corroded connections? Also you might want to confirm the amp draw...your breaker could be bad
Thanks, Marty
Marty's 'BearsMobile'
1995 Dodge SMB EB-20 + modified for shower in back, PH Microlite Starcool. 130k miles young!
https://www.sportsmobileforum.com/alb...a37caeae3a.jpg
mmocken is offline   Reply With Quote
Old 07-31-2013, 08:07 PM   #35
mmocken's Avatar
For my '95, Replaced the evaporator and the check valve gasket...
Still running fine, original starcool, engine compressor and hoses. R134
Thanks, Marty
Ford
fabtechmfg
Testing
Tech Admin
