The Fridge isn't Refrigerat'ing
I don't have the spec of the fridge with me, but it's more than likely what SMB installed back in 1993.
Arrived home from our last little weekender trip and while unpacking the fridge noticed that, although the little green light is on, indicating that the fridge is ON, that everything wasn't as cold as it should be. Since then I've tried to turn the fridge on and off, adjusting the temp setting, but it doesn't seem to "kick in" like it used... as if the compressor (or whatever it is that makes the little humming noise) isn't kicking in when I turn the temp dial up.
Are these fridge's serviceable? Anything I can check for on my own before I have to drop some serious coin for repair or replacement?
<edit> oops, wrong forum - can someone move to appliances please. sorry about that.
