Old 03-29-2015, 08:06 PM   #11
Re: Thetford Curve not flushing
I had the same issue last summer with an in-warranty Curve. Thetford shipped me a new one no questions asked. I called their 800 number, and they walked me through the diagnosis- same corrugated tube split. They said that it was unrepairable, so sent me an entire new unit.
John
slfjas is offline   Reply With Quote
Old 03-29-2015, 08:13 PM   #12
BrianW's Avatar
I have a Curve but haven't used it much. No problems yet. Sounds like maybe a preemptive addition of a hose clamp to that tube might be in order.
Old 06-24-2015, 06:03 PM   #13
I am about to order a curve.
Does anyone see a reason why NOT to add a hose clamp before we use it?
Is there some compelling reason why this isn't a fix from the factory?
Onefin is offline   Reply With Quote
Old 06-25-2015, 12:01 AM   #14
rockbender's Avatar
I must admit that when I read the title I thought to myself "well that's a sh!++y problem to have!"
Awesome that you documented the fix, Larrie. Well done!
Josh
Old 06-25-2015, 09:56 AM   #15
As chief engineer aboard passenger vessels,I have had plenty of experience with toilets, and have yet to find one that didn't have some sort of design problem. My personal boat has a Tecma ($1200!) from Theatford that had an issue that caused it to stop flushing at least twice a year. Fixing it was a messy, time consuming project. I called the US factory and explained how to eliminate the issue, but they insisted they had never heard of it, and I was the only one to complain. Fast forward four years and I found out I could get a redesigned part from Italy that incorporated a proper fix. Theatford in the US again had never heard of the part, and I ended up importing it. If someone could invent a simple, reliable toilet I think there is a huge market. (meanwhile, a bucket will never clog or refuse to flush) Then all I would want is a toaster that works. Glad you found the issue though, a new hose should be pretty simple to install.........
Old 06-25-2015, 10:45 AM   #16
vwteleman's Avatar
More fibre?
Old 06-25-2015, 10:56 AM   #17
larrie's Avatar
If I did not have a Curve I would still order one. We like it a lot. Adding a hose clamp might be a good preventative measure.
Larrie
Old 06-28-2015, 07:46 PM   #18
Thanks for the reply.
I am just going to order it and then look forward to cleaning it for my wife and daughter.
Funny how much time one can spend researching a port-a-potty.
Old 08-15-2015, 11:31 AM   #19
skyrat's Avatar
Will the Curve fit in the standard SMB Porta Potti cabinet?
George ><>
2005 5.4L E250 RB50 4x4 SMB
2000 4Runner Limited 4WD
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
skyrat is offline   Reply With Quote
Old 08-15-2015, 12:20 PM   #20
larrie's Avatar
The Curve is 17-5/8 h by 17-3/4 d by 15-1/4 wide, http://thetford.com/product/porta-potti-curve/. Not sure what you layout is but I put mine in one of the closets and pull it out when needed.
Larrie
