Re: Water Tank Fill Question
I don't understand your issue, do you want to ensure it is full or ensure it doesn't overflow?
My system is dead simple. Hook up water to inlet. Turn valve to fill, close valve either when you see it full or when it runs out the overflow under the van.
To fill manually, open cap o top side of tank and fill through there.
To use city water, don't turn pump on, hook water up, use it.
To use tank water, turn pump on. Basically either one will pressurize system.
Sportsmobile-less.
