Old 09-02-2020, 10:55 AM   #611
REDOVAL's Avatar
Welcome to September! We've been on a roll recently with the current 10% discount available so we have continued it through Sept. Use code SMBSEPT20VO to apply the discount and pick up those Vantage Optics products! As always contact us with any questions.
Scott Thompson
Vantage Optics
vantageoptics.com
Vantageoptics@gmail.com
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 10-03-2020, 06:09 PM   #612
A couple of electrical questions for someone who's less of an electrical dumbass than myself:
The directions say to connect positive to the "fuse block terminal." I google search reveals that some fuse blocks have a positive terminal in the middle. Mine doesn't. (see pic)
I'm assuming where I connected it works (It's labeled +, the one next to it is labeled "alt") but I'm always a bit shy about hooking the battery back up before I'm sure. Any thoughts?
And, the negative connection for the passenger-side light is close enough to connect it to the battery. Can I do that, or is a chassis negative preferable?
Thanks for any advice!
MorieSugg is offline   Reply With Quote
Old 10-03-2020, 06:29 PM   #613
REDOVAL's Avatar
You have the 12v lead connected correctly. The passenger negative connection is easily made in the factory location in the corner by the starter relay.
Scott
Old 10-06-2020, 10:18 AM   #614
REDOVAL's Avatar
How is it already October? We have been insanely busy building lights and working through new product development. One new product that we just launched is a set of laser cut and formed stainless steel ballast mounts for the Econoline vans. Known fitment at this time is the 97-current vans with the gas and 7.3 engines. We need a 6.0L variation to test but we are quite certain they will work perfect. Check out the link below for details and the video to show how easy they are to install. They can be added to current setups as well if you wish to have a cleaner install and easier access to the ballasts.
https://www.vantageoptics.com/shop/V...ets-p238959982
In other news, since we are into a new month, the current SMB coupon code is SMBOCT20VO
Scott Thompson
Vantage Optics
vantageoptics.com
Old 11-09-2020, 03:44 PM   #615
REDOVAL's Avatar
It's now November and we've got tons of product on hand ready to build your headlights and Econoline accessories! Use code SMBNOV20VO to save 10% on your purchase!
Scott Thompson
Vantage Optics
vantageoptics.com
Old 11-18-2020, 01:58 AM   #616
I noticed this is a old post, are yhey still available? I have a 2013 Ford e250.
htrowrod is offline   Reply With Quote
Old 11-18-2020, 09:11 AM   #617
REDOVAL's Avatar
There are versions that are, but we have to use your original used headlights in good condition (clear lens, no broken tabs, etc).
https://www.vantageoptics.com/shop/2...ghts-p72045183
Scott Thompson
Vantage Optics
vantageoptics.com
Old 12-21-2020, 10:36 AM   #618
REDOVAL's Avatar
Well, the Holidays are here and we have parts in stock! Use coupon code
VOHOILIDAYS for free shipping and a 10% discount good though Jan 3. Please note that we are doing our best to process these custom builds and need about 2-3 weeks to get them out the door (most sets are done much quicker). Thanks and Happy Holidays!
Scott Thompson
Vantage Optics
vantageoptics.com
Old 01-04-2021, 08:28 AM   #619
REDOVAL's Avatar
New Year, new coupon code! Use "JAN2021" for a 10% discount on all orders through https://www.vantageoptics.com/shop
We will have some new products available very soon as well that will be awesome add-ons in addition to the headlight builds!
Scott Thompson
Vantage Optics
vantageoptics.com
Old 01-08-2021, 12:05 PM   #620
REDOVAL's Avatar
Here's a teaser for our newest Econoline product, the VO Underhood Service Light Kit
https://www.vantageoptics.com/shop/V...Kit-p276199702
Ford Econoline vans from 1992-2007 (08-current kits in process) do not have any provisions for light in the engine compartment. If you've spent any time around vehicles you are aware that they never break or need work when it's most convenient! This kit aims to provide an easy to install light kit that provides plenty of usable output with a push button on/off switch. As an added bonus this kit allows for an optional remote light and extension kit to provide light exactly where you need it on the vehicle.
Features-
-Application specific kit (universal also available soon)
-High output LED light with aluminum housing
-Push button on/off switch
-All wiring/connections provided
-Fused power lead for protection against over-current
-Minimal modification needed to install
-Single Weatherpack lead for system expansion
-Optional remote Profile magnetic work/camp light assy
Scott Thompson
Vantage Optics
vantageoptics.com
20201230_171758.jpg   20201222_143434.jpg   20201222_142529.jpg   20210104_173943.jpg   20210104_174001.jpg
Vandit
aarcaris
Dodge
lugee
