Old 11-22-2012, 09:16 PM   #51
Re: Hola! My official introduction - 2002 White SMB EB50 7.3
WTF I don't know why they did that! But now that I'm thinking about it I did have them use a smaller tube diameter on mine to save weight... maybe that has something to do with it but I doubt it. SMB and several members here have the same rack (with standard tubing) using the same panels. Is it possible Kyocera is producing a different size panel? I mean it dosen't look bad but I still don't know why they did it. Because my rack was custom, when I speced out my rack I had all the drawings how I wanted it, all the way down to how wide the flat bars were spaced.
Is your top different than mine?
Dave
Old 11-23-2012, 12:33 AM   #52
Hola! My official introduction - 2002 White SMB EB50 7.3 4x4
Dave
Not sure if we have the same roof or not.
The Kyocera kd135 is a pretty standard dimension. Even the new kd140 is the same. I think the fact that you have smaller diameter tubes is why your rack didn't need to bow out.
I emailed Kenny letting him know my dissatisfaction. Lets see what happens.
Old 11-23-2012, 12:06 PM   #53
You might call Peter Deltoro and ask about all the racks they have ordered and installed at SMBW. They're the ones who mount the panels. Like I said, I've never seen that before but then I really haven't looked that close.
Old 11-23-2012, 09:44 PM   #54
Jacko, I looked at my rack today. It is the same as yours! The angle is subtle but is there. That brought back some memories when I had mine done. I was warned about that because they said (if I recall correctly) the tops angle is “more narrow" at the back. Funny how I never noticed it. So the tube diameter may indeed have something to do with it being so noticeable. Sorry I didn't remember what Aluminuss had told me. Of course it means the angle will determine where (how many) panels can be put on the rack. I planned for and installed 2 panels. Hopefully Aluminuss built your rack for future add on but maybe you don’t want that.
Dave
Old 11-24-2012, 12:11 AM   #55
Dave - thx for checking. I told them I wanted a rack like yours. Mounts fir 2 panels installed sideways. In the bear future ill add a 2nd panel.
Didn't realize I could get smaller diameter tubes. Makes sense for weight reduction which I realize is so important now especially since I'm at the tipping point of too much weight that causes the top to be difficult to lift.
Btw - is it better to install the panels in parallel or in series?
Old 11-24-2012, 02:46 PM   #56
buckkiller's Avatar
Ocsmb,
love your rig bro,hope to have my build out done asap.
Buck
"The Redneck Mexican"
2002 E350 EB 7.3 Clydesdale 4x4 w/8' lift,
Colorado Camper Van pwr top,
Van Specialties build out
buckkiller is offline   Reply With Quote
Old 11-24-2012, 05:10 PM   #57
Mine are 17v panels wired in parallel.
Old 11-24-2012, 07:10 PM   #58
Originally Posted by buckkiller
Ocsmb,
Buck
Thx dude!
Old 11-25-2012, 07:56 AM   #59
Tapatio's Avatar
If you wire in series you'll double the voltage (17v to 34v) and burn out your solar controller (max 30v). Wiring in parallel will double the amperage (8a to 16a) but that's ok since the controller can handle up to 25amps.
Positive to positive, negative to negative.
Callsign KK6GIY
Old 12-02-2012, 11:33 PM   #60
Thx to Tapatio my pop top is good to go. 2 links and pushing the top is almost like I have no rack and panel.
Also added a little bit of wood to the rear of the helper springs.
