Old 10-25-2014, 07:01 AM   #1
12v Radiator Fan Instead or + Clutch Fan
G'day,
Does anyone in thier 6.0 diesel radiator area have a 12v electric fan for cooling radiator instead or as well as factory Ford clutch fan?
If so, what make 12v fan?
2008 Yellow Ford E350 6.0 diesel eb50 4x4, Front E Locker, Asheville Eng Rebuil 20th @ 261miles, ARP Studds, 200amp Alternator, Performance Aluminium Radiator, OnBoardAir, RoadmasterActiveSuspension, Front & Rear Aluminess with Spare Tire Carrier, Aluminess Roof Rack, Titan Aft 30gallon Fuel Tank.
Sheriffdoug is offline   Reply With Quote
Old 10-25-2014, 10:39 AM   #2
Re: 12v Radiator Fan Instead or + Clutch Fan
I'm not aware of anyone who makes a 12V fan that moves enough CFM to cool that motor. You could probably build your array of smaller fans and make it work, however at that point you risk overloading the alternator at idle, which can damage the FICM.
An aux 12v fan should be fine though, and still provide additional cooling at idle. Ford did include it in some versions of the V10. There is a diagram here of how it mounts:
https://www.fleet.ford.com/truckbbas...tml/Q179R1.pdf
Silver Streak
Glider
Zengi
Amy V
