Re: Extreme Air questions
Do you have it permanently mounted, or is it mobile? If permanently mounted, is it mounted inside the van or outside?
As for the air tank, I always leave it depressurized. The compression of air drives out moisture, so there will always be some small amount of water that collects in the tank. After using a compressor with a pressure tank, I always turn off the compressor and then drain the moisture from the tank to eliminate the water. Even though it would take quite some time to weaken the pressure vessel, the water can accelerate the rusting of the air tank from the inside out. Not a good idea with something that will hold 130 psi.
