Old 08-15-2012, 03:17 PM   #31
twogone's Avatar
Re: Hi Lift Jack
Totally not like my Powerbuilt... except the 4" part... I carry a short bottle jack to get up off of a flat (haven't had one yet) or you can pull up onto some leveling blocks to get enough lift.
Wait til you see how much that C'man rattles and 2 tons seems woefully light duty. No cradle and no jackstand... all depending on that fine tiawanese/mexican/detroit o-ring. No matter where it was made, it is just an o-ring
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 08-15-2012, 09:21 PM   #32
BIGVANS's Avatar
Re: Hi Lift Jack
I for one am getting a little “discouraged” with all the changes made to products these days! But at least everything is made with more lead in it!
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 08-21-2012, 05:46 PM   #33
Re: Hi Lift Jack
Well this is going to be my jack setup.
I bought a PowerTeam 6 ton telescoping jack. It has a range from 8.5" to 20.5". 14 pounds. Feels like really great quality. Made in Germany. Too expensive at $283. It drives me nuts that it doesn't have a really secure "saddle" to hold the axle, but none of the jacks seem to have one.
I also bought the Napa "pro" jack stands. Made in China, but seems OK.
I will carry both.
What do you guys think?
edroid is offline   Reply With Quote
Old 08-21-2012, 07:42 PM   #34
Re: Hi Lift Jack
Looks fine, just remember if you can't get to the axle there might be problems. For me that can be a huge problem while off roading. You might want to look at a bottle jack axle cradle as well for it.
http://www.swagoffroad.com/Bottle-Jack- ... _p_66.html
Old 08-21-2012, 09:16 PM   #35
BIGVANS's Avatar
Re: Hi Lift Jack
The bottle jack axle cradle or your own version of it is a good thing to have.
You will wish you had a Hi-Lift with a Wheel Lift if you bury one or both wheels up to the axle in mud or sand, you can’t get a bottle jack under it then.
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 08-22-2012, 09:32 AM   #36
Re: Hi Lift Jack
Thanks for the tip on the Swag bottle jack axle cradle. If it works as claimed, it solves the one huge glaring problem with 99% of the bottle jacks I have looked at. I am a bit concerned on the leverage that the large cradle could put on the jack cylinder. . . But we'll see. (By the way, I ordered the cradle after 10pm, and got an email that it had shipped ten minutes later!)
As far as the Hi-Lift, I have the jack, the tire attachment, I've installed the mounts, but I just don't want to carry that beast unless I am planning a really an extreme trip.
To paraphrase the old joke, I want to know where I am going to get stuck, and I just won't go there. . .
Old 08-24-2012, 04:13 PM   #37
Tapatio's Avatar
Re: Hi Lift Jack
Hi-lift jack's are very multi purpose....
Callsign KK6GIY
Old 08-24-2012, 05:48 PM   #38
Re: Hi Lift Jack
I don't know what they were sayin Ron but it musta been something like "wonder who the idiots were who built this fence". That said, I don't I don't know what is on top of the fence but a couple a aluminum ladders might have been just as easy. Maybe ladders are too suspicious around the border.
Old 08-24-2012, 07:13 PM   #39
Tapatio's Avatar
Re: Hi Lift Jack
Pretty sure it was "hurry up, hurry up, get the drugs to your drop off point. As a bonus I will give you $1,000 more if you bring back one of those cool 4X4 vans."
Callsign KK6GIY
Queen bee
Deaner
Moby
new2tx
