Old 01-17-2011, 09:39 PM   #21
Re: how many miles on your 6.0 smb?
Originally Posted by bitburger
Last weekend, my check engine light came on.
I call that my Replace Turbo Light. 12K, 20K and 33K replacements or service.
PatO is offline   Reply With Quote
Old 01-17-2011, 11:29 PM   #22
Wow! Do you let it sit for extended periods? Do you use cetane boost?
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 01-18-2011, 05:04 PM   #23
Location: Rolling Hills, Mammoth Mountain, Coeur d Alene Idaho
24000 miles no problems except looks like I've just lost a OME shock up front making the handling spooky. Oil changed religiously at 5000 miles. Idle only long enough to drop temp down to 200 or less. Had a 2003 F350 that lost a turbo at 27000 miles than was good until 105000 then they put 3 in to find a good one and at that point I donated it to the Make A Wish foundation as repairing off warranty is to be avoided like the plague.
2008 xlt 6.0 psd
Cali Native is offline   Reply With Quote
Old 02-08-2011, 06:20 PM   #24
Greg In Austin's Avatar
We have approx 40k miles on our 2008 6.0.
Zero problems, but we also drive it easy.
AND we did invest in the extended warranty.
Greg in Austin
Old 02-09-2011, 05:48 AM   #25
We have 37,000 miles on the 2006 6LPSD with one turbo replacement at 30,000. I use the Amsoil cetane boost regularly.
It's time to buy the extended warranty in the next several months!
2006 Baja Tan SMB 4X4 EB50 PH 6LPSD
Mohawk Royalex Solo 14 foot canoe (light white-water)
Mad River Kevlar Explorer 17 foot canoe (flat water)
Dagger Royalex Legend 16 foot canoe (white-water)
Maravia New Wave 13.5 foot raft (fishing and white-water)
Ed in Montana is offline   Reply With Quote
Old 02-28-2011, 05:51 PM   #26
JoeyNick's Avatar
I'm just over 90k with no engine problems to date, AND I have a tuner.
I've used a fuel additive with each tank from day one, plus Mobil 1 synthetic oil since the first oil change (and every 5k thereafter.)
JoeyNick is offline   Reply With Quote
Old 02-28-2011, 11:42 PM   #27
What brand additive are you using Joey?
Thanks
Dave.
Old 04-27-2011, 05:49 PM   #28
lobo_q3a's Avatar
Send a message via AIM to lobo_q3a
I've had my vanes cleaned once at around 15K and now, @ 24K, the light is on with a turbo error code. My van sits a lot and I am turbo diesel noobie. I have not purchased the extended warranty from Towne Ford (my van is a 2006) and i'm about to go in to (presumably) have the vanes cleaned again.
Is there someone else who could do this besides the stealer?
What are some great options for monitoring ECT and EOT?
Are there any other things i should have down while the van is getting its vanes cleaned? Like replacing the EGR cooler and oil cooler? (I'm running Amsoil).
We love this van and i am now wondering if i have been babying it too much. I need the van to be rock solid while we are out and about in it.
Thanks for all the info Saline!
lobo_q3a is offline   Reply With Quote
Old 04-27-2011, 05:59 PM   #29
Lobo - sounds like you need to drive it harder. Hook up a trailer, find a long hill, and keep you foot to the floor.
Old 04-27-2011, 08:21 PM   #30
Yep, read enough on the diesel boards and you'll see this is exactly what most recommend for the 6.0psd. The motor was designed to be driven hard, not babied. If you don't get full boost on the turbo once in awhile, carbon can accumulate on the turbo vanes and cause them to stick. At full throttle/boost, the turbo spins fast enough to fully articulate the vanes, which is necessary to blow out carbon deposits and prevent sticking. Counterintuitive yes, but to make the motor last you need to hammer it regularly.
I try and drive the van weekly or at least every other week at the longest. And every time I'm driving, after full warmup, will do a few 10-30 second full throttle runs up to 3500rpm or more. Easy to do when merging onto the freeway. For a 10k pound vehicle, it can move pretty well.
R
2006 SMB 4x4, EB-51, 6.0psd
EMrider is offline   Reply With Quote
