Old 03-12-2009, 11:53 AM   #11
Re: How much does your van weigh?
I weighed total, front and rear axles, plus each tire which told me I needed E rated tires.
Old 03-14-2009, 06:00 AM   #12
8,600 lbs w/ half fuel and unpacked for travel,no h2o.
4180 lbs front axle.
4460 lbs rear axle.
07 E-350
patrick51 is offline   Reply With Quote
Old 03-14-2009, 06:03 AM   #13
Does anyone know the van weight prior to SMB's build-up? If they truly do not change the springs, there must be a big difference in the ride comfort.
07 E-350
Old 03-14-2009, 11:24 AM   #14
Pat, I'm glad I've waited to deal with the springs b/c of all the extras I've added. My van was definitely lighter at delivery.
I probably won't add much more now so Devers can dial it in better. I just have to make the commitment to spend that much. Other than the shutter on washboard, my van rides and corners great. No sway or hitting the bump stop hard like so many complain about.
Dave
Old 03-14-2009, 04:38 PM   #15
We just picked up the finished van from SMB Indy on Monday. We used it last summer with no interior, so I have weights from then also. It's an RB 50 basically, but no heat or AC. We have 2 batteries and a small refrigerator. Pictures later I hope.
(Left) Quigley Info empty before SMB
(Center) Weighed in CO on vacation before SMB
(Right) Completed interior from SMB IN
Act Front 3743 3940 3920
Act Rear 2835 3640 3780
Act Total 6578 7580 7700
Old 03-16-2009, 07:58 AM   #16
Pat here is the other similar link about weight.
viewtopic.php?f=2&t=1134&hilit=public+scales
Old 03-16-2009, 01:29 PM   #17
geoffff's Avatar
Confusingly, this topic is also identically named "How much does your van weigh?"
Check it out...
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 03-16-2009, 06:02 PM   #18
Want they should be merged into one?
Old 03-16-2009, 06:11 PM   #19
It's sorta like back tracking on trails now.
Can one be deleted if there are no pics attached?
PigPen
velo47
Big Mable
Fikeadelic
