Old 06-09-2018, 11:04 AM   #1
Jacking front of e350 quigley.
So where the heck do you jack up the front of the quigley e350? Rear is obvious. Front not so much.
I've got either a floor jack or agile's adapter for the scissor jack from the hummer to lift the van with. No place on the front axle to lift with. due to the non centered pumpkin on teh diff.
Front part of the frame?
rean1mator is offline   Reply With Quote
Old 06-09-2018, 08:43 PM   #2
WhitH's Avatar
Why not the axle? When I added new coil springs to mine I took the front bumper off and used the hi lift in the frame but just for changing a tire or something seemed like the axle worked fine.
Sold 2005 E350 Chateau
Old 06-10-2018, 08:29 AM   #3
1der's Avatar
Sounds like you are wanting to lift both tires at the same time? Is the concern lifting on the center of the tube part of the axle?
I lift one side at a time and use jack stands, or if changing one tire, I lift off the end axle towards the tire I want to change.
Old 06-13-2018, 10:38 AM   #4
I'm most concerned about the jacking point on the front left of the vehicle. I was able to jack the right front side no problem.
Can't seem to find a suitable spot to jack from. The pumpkin is on the left side so axle is not an option. I think the manual says where the radius arm meets the axle?
Ok to jack at the radius arm?
Old 06-13-2018, 01:24 PM   #5
simplesez's Avatar
I just jack on the pumpkin and put a jackstand where the radium arm connects.
BTW, a photo of your set up would help a lot.
Old 06-13-2018, 01:40 PM   #6
Ok will try that method. thnx
Old 06-14-2018, 06:16 AM   #7
Oogs's Avatar
I had an 04 Quigley. I would Jack the pumpkin and had just enough room to the side to place a jack stand.
Sent from my HTC6535LVW using Tapatalk
Oogs is offline   Reply With Quote
Old 06-14-2018, 07:45 AM   #8
Anywhere on the frame but it does take a very tall jack.
