06-21-2018, 04:29 PM
#31
Originally Posted by MountainBikeRoamer
Ok this is just off the cuff, but....
....seems to me, if you're truly seriously inclined to gear up and DIY a fiberglass van body onto a cutaway....and you have a super-nice/low-mile cutaway chassis with a desirable motor/transmission in it....one might as well consider finding a clean, scrapped **actual Econoline body** and simply having that welded to the back of the cutaway cab.
Probably way cheaper and better structural results, to TomH's line of commentary. Nice welds don't leak, unlike those fiberglass-to-steel bonded joints might!
That might work. You still want to think about 4x4 conversion, lift, suspension upgrades. You might see if SMB would do only that part. There's also Quigley and others. You could also look into just buying the Fox shocks, extra leaf springs, F-550 parts, Dana axles and DIYing all that if you have the tools and knowledge.
06-21-2018, 04:44 PM
#32
after my experience with agile, and having them an hour away, they get my money if i ever convert another van to 4x4.
06-21-2018, 07:19 PM
#33
x2! Great guys and product
2008 E350 RB 6.0 - Bullet Proofed, MG 4x4 Conversion
2009 E350 RB 5.4 - Camburg Kit (Sold)
06-21-2018, 07:48 PM
#34
Originally Posted by TomH
YES, but you have to find the vehicle, buy it, and bring it to them. It also has to be in decent enough condition for them to do the work. Now understand that they don't just do the top and interior. They use F-450 and F-550 (pickup) parts to replace the entire driveline, convert to 4x4, install F-550 brakes, replace the axles, install highly advanced shocks, lift, extra leafs (leaves?) in the leaf springs, and give it an extreme amount of axle float and articulation. They make the low range gear box themselves-their own patented design. You get to choose between differential locks, limited-slip, etc. With the amount of changes they make, you wouldn't want to pay for all this to be done to a worn out body and frame. They do all that same stuff to the new "Classic" on the cutaway as they used to do on the cargo van. And they will still do it to a cargo van if you can bring them one in decent shape.
Actually, they use Dynatrac axles and the Advanced Adapters Atlas II transfer case. At least that is what is on my 2012 SMB.
Chris/Bev
2012 E350 EB50 V10 Cruiser Top
Sportsmobile 4WD Conversion
06-24-2018, 03:54 PM
#35
Yes Dynatrac and an Atlas II were used 2013-2014 cutaway and I'd assume they wouldn't have changed the design.
07-01-2018, 02:21 PM
#36
SMB just posted this to Facebook.
Sent from my STV100-1 using Tapatalk
07-02-2018, 01:44 PM
#37
Progress! Finally! Any word on a price point for these yet?
07-02-2018, 02:34 PM
#38
Last time I asked, it sounded like a fully rigged one with winches, etc., would be close to $150,000.
07-02-2018, 04:09 PM
#39
I was at the factory in Fresno 2 weeks ago. Brian said $160k. I don't remember whether that was the average or one specific vehicle we were looking at.
07-02-2018, 04:15 PM
#40
Wonder where all of the extra cost comes from? I would assume the cutaway is cheaper than the full van. All the rest would be the same outside of the cost for the fiberglass shell. Mine was nowhere near that in 2013 and I had it pretty loaded up.
