Old 03-10-2019, 04:18 PM   #1
KyleC's Avatar
Tire size for 99 e150
Asking for an aunt and uncle, they just got an 99 e150 with only 9,000 original miles! What is the largest tire they can install on stock ride? I have 265/75/16 and I don't have any problems rubbing. But I don't want to give them bad advice!
KyleC is offline   Reply With Quote
Old 03-10-2019, 04:35 PM   #2
They’d do well staying with stock if it has stock rims. Info is on the door tag.
Peace, Regis
2011 Express 1500
I'm a camper not a glamper
regis101 is offline   Reply With Quote
Old 03-10-2019, 05:41 PM   #3
BrianW's Avatar
Largest stock tire size is 245/75r16 on the Econolines. These came OEM on the E350s.
Old 03-10-2019, 06:42 PM   #4
I'd bet dollars to donuts that that e150 is sporting' 15's.
Stock rims would do best with stock tires.
Wider rims can be used but one must be careful if the side door is a slider.
Wider tires on stock rims defeats the sidewall engineering.
Stock tires on wider rims defeats the sidewall engineering.
Taller tires can be used but one must be careful about gearing.
blah, blah
Peace, Regis
2011 Express 1500
Old 03-11-2019, 04:41 AM   #5
The 1999 E150's were "true E150's" in that the frame and springs were lighter duty than E250's and above OR the later E150's which were just E250's in disguise.
Sticking with the stock tire size as shown on the door tag is the best advice so far. With only 9K miles on a 20 year old van says they don't really need anything special in tires.
Old 03-11-2019, 04:51 AM   #6
KyleC's Avatar
Fantastic guys. That is why I held my opinion jwa. Thanks for the quick responses. Hoping to get them to join here. They plan to build out the interior some and travel. It was an old crime scene van from what I understand.
Old 03-11-2019, 04:07 PM   #7
I had had a 98 E150 Club Wagon for a few years. There are plenty of tire choices in the XL load rating. No harm no foul if they want to step up to an LT in the 110 and up load .
One more thought then I’ll stop. It’d be cheap insurance if they spring for five new tires. Just sayin
Peace, Regis
2011 Express 1500
Old 03-12-2019, 06:09 AM   #8
IanF's Avatar
OE tire size should be 235/75-15XL. Be sure to get the XL rated tire if any sort of loaded driving or towing may happen. That said, in my ignorance I got away with P235 (passenger car) tires on my old 1990 E150 conversion van for many years. The P-tires have fewer belts and will generally ride a bit smoother and are usually cheaper. And I agree with the above comment the spare should match.
IanF is offline   Reply With Quote
Old 03-16-2019, 05:52 AM   #9
Good advice on buying 5 new tires----never know when a flat will happen.
Here's something I found that might be helpful here and all of SMB, a tire size comparison gadget: https://tiresize.com/comparison/
HTH
2015 Ford E350
Hondo
Babe
Babe
