Old 10-06-2011, 06:42 AM   #11
Re: Using Compressed Air to Blow Out Water Lines
Originally Posted by jage
Originally Posted by bluesprinter
The pump and lines are inside,
Are you sure? My lines, hot and cold, went up the driver wall diagonally, over the rear doors and down the passenger wall.
Incidentally, I also found two new, never opened line drains so far under the water heater I couldn't have turned them if I knew they were there.
Pump is definitely inside, as is the fresh water tank. Under the couch/bed. The lines are inside the walls, but on the interior side of the insulation.
bluesprinter is offline   Reply With Quote
Old 11-01-2011, 09:29 AM   #12
ANZAC's Avatar
Btw re pressure, I found a cheapo plastic fitting with schrader valve and it says "max 50psi" which is probably plenty anyway. I have a huge tank on my compressor, I am going to run it up to 50psi and then shut it off, and then use it from there to blow out.
Sportsmobile-less.
Yeti
ACTNPKRYETI
Priscilla
DocMP
