Old 10-15-2007, 06:50 PM   #1
Small Projects Thread
Starting a thread for small things you do to make your SMB better- things that wouldn't really warrant a complete project posting. (Just REPLY to this message with your mini-projects)
Update: I'm going to delete all the comment-only posts. Please discuss in other threads (e.g. start a "In the small projects thread..." post if you're not improving or adding a new project). Thanks!
Old 10-15-2007, 06:52 PM   #2
Marking the Shore Power Outlet:
Just made an indelible line where it plugs and unplugs- the lines don't line up because it is twisted to "lock". Makes it a lot easier to pop the shore power in, although the indelible ink faded in the sun when I left the plug out.
Update: The marker continued to fade so I took a cutoff disk (essentially a large dremmel) and cut a groove instead. I'll fill it with glue or plastic or something if I ever come across some suitable material.
Old 04-04-2008, 08:53 AM   #3
Send a message via Yahoo to lowracer
SHORE POWER LABEL
Great Idea. I also used a label maker to label right above the connection point:
110V MAIN CB OFF
just as a reminder that the main breaker has to be off before connecting or disconnecting this plug. I've labelled a lot of stuff in the van as reminders since I don't like reading the manual every time we camp.
Tent camping for now. Dreaming up a new 4x4 SMB. Gas or Diesel?
lowracer is offline   Reply With Quote
Old 04-20-2008, 02:52 AM   #4
Buji's Avatar
NOISE REDUCTION
get a 10 foot roll of weatherstripping. Have someone else drive the van on some crummy roads and start hunting rattles.
-Buji
_________________________
Modified EB-22 with Penthouse Top
https://www.sportsmobileforum.com/alb...43791a54be.jpg
Buji is offline   Reply With Quote
Old 05-11-2008, 12:32 PM   #5
yvrr's Avatar
I don't think that SMB mounts switches for the off-road lights and backup lights down in the left knee area anymore but that is where ours are located and it was very easy to accidentally turn on one of the switches. (We once drove over Donner Summit at night with the Hella backup lights on...we couldn't figure out why everyone behind us were flashing their high beams!)
Here is a simple solution:
Jack
'01 Ford EB50p Quigley 4WD
Old 09-01-2008, 09:50 PM   #6
mmocken's Avatar
Send a message via AIM to mmocken
Increased padding on penhouse beds with 1.5" memory foam. Much better! Easy mod.
There is a slight interfearance between the last 6" of the PH bed...it gets compressed by the spring cover. Fortunately, memory foam is very compliant and compresses nicely without major resistance.
Thanks, Marty
Marty's 'BearsMobile'
https://www.sportsmobileforum.com/alb...a37caeae3a.jpg
mmocken is offline   Reply With Quote
Old 09-01-2008, 09:57 PM   #7
mmocken's Avatar
Bed Extension and shelf
Made a shelf that fits in PH bed ledge.
Comes in handy when cooking for more counter space.
Also handy for a little extra room for the upstairs mattress so my feet aren't dangling over the edge.
Here is pic ready for storage. Fits above the mattress when the PH is lowered.
Thanks, Marty
Old 09-11-2008, 11:04 PM   #8
Fridge Thermometer
I've added a digital thermometer to our fridge, just a little trimming of the grill, the hardest part was removing the fridge and finding a way to get the sensor in via the drain hole.
$20 from Aerostich http://www.aerostich.com/catalog/US/...r-p-17545.html
tadg is offline   Reply With Quote
Old 11-02-2008, 06:06 PM   #9
charlie56's Avatar
I typically park in my driveway in front of my garage. Rather than risk hitting the roll-up door, I open the garage door every time I pull up. Having the door opener clipped to the overhead didn't look so good. This small project makes it look like a built-in feature. It is nothing more than the standard remote with a momentary switch installed. The tough part was finding a rocker-type momentary switch to match the others. (found them for $3 at http://www.oznium.com/switches)
The remote is velcro'd to overhead hidden from view so i can get to it to change the battery.
Before view
The Modification
Add a short section of 22 ga wire, solder to the existing switch on the remote.
After view
... Charlie
KZ6T
Old 03-08-2009, 10:49 AM   #10
charlie56's Avatar
Re: Small Projects Thread
Ever travel down a washboard and have the bottles of spices or whatever come flying off the shelf above the galley? To stop that, I installed two 4' long "flat" bungy chords across the opening. Just ground down the hooks and thru-bolted the plastic ends to the overhead. Works great. We can put jars and bottles up there now and they don't rattle out.
... Charlie
KZ6T
EB Van
ebflow
Rosy
Isever
