Old 05-19-2012, 03:54 PM   #1
Mud Flaps AND Rock Sliders
Hey all - put on mud flaps and rock sliders and am posting pics. I purchased the mud flaps online from Pro Flaps. You have to buy the Lifted Truck Ford Flaps #105. The 105 flaps are for the front but I used them for the rear also because of the cutout it works for our lifted 4x4 SMB Ford Vans front and rear. A set of 2 is $116 each, so was about $250 w/ shipping, etc. The flaps are rugged 1/4 inch think heavy duty rubber but will flex some. They were modified to fit on the SMB.
The sliders are made of 2 x 4 by 1/8 inch box wall steel. The cross members are the same but 2 x 2 inch. It's all welded together and welded to the frame in 4 places each side. There is NO interference with removing/replacing anything under/attached to the van. The top of the slider was spray coated with bedliner spray-on so it's grippy when stepping on it. Everything was cleaned and spray painted and all ends welded shut - no water can get in the sliders.
Not just the mud flaps will prevent mud CAKING the side of my van. I sacrificed very little clearance and got great mud protection from the sliders too - and body protection of course. The cross members are angled up higher than the frame so they provide no clearance issues. In addition, because the sliders stick out just flush with the bushwackers, they provide an excellent foothold for ingress/egress and a platform for standing on to clean, etc.
2010 E350 RB 50 Ash Gold V10 gas engine w/mud flaps and rock sliders!
2011 VW GTI
2009 Tacoma 4x4 TRD
warholic is offline   Reply With Quote
Old 05-19-2012, 04:01 PM   #2
Re: Mud Flaps AND Rock Sliders
More photos
2011 VW GTI
2009 Tacoma 4x4 TRD
Old 05-19-2012, 04:10 PM   #3
more pictures ... trying to figure out how to post pics on this site
2011 VW GTI
2009 Tacoma 4x4 TRD
Old 05-19-2012, 04:16 PM   #4
last 3 pics
2011 VW GTI
2009 Tacoma 4x4 TRD
Old 05-19-2012, 05:20 PM   #5
BIGVANS's Avatar
NICE!
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 05-21-2012, 08:32 AM   #6
Really nice work! Did you do all that in your driveway? Looks like you put in quite a few hours on your back.
John
jwintersteller is offline   Reply With Quote
Old 05-21-2012, 10:21 AM   #7
Thx -
There is a shop nearby and the owner is a real car guy and can fabricate anything. So we came up with the design and he did it. There was a lot of labor involved so it wasn't cheap even tho' I got a discount.
warholic
2011 VW GTI
2009 Tacoma 4x4 TRD
Old 05-23-2012, 10:46 PM   #8
notmiller's Avatar
Awesome job! Very clean and professional looking.
notmiller is offline   Reply With Quote
Old 06-05-2012, 03:03 PM   #9
Do you have the grey water tank along the passenger side frame rail?
If so, how did you clearance the tank? Mine hangs down a little farther than the lower rocker.
Great work by the way!
1995 SMB Quigley 7.3 EB
"a quality, stock 460 is a real pleasure" - twogone
blupaddler is offline   Reply With Quote
Old 06-05-2012, 03:41 PM   #10
hey there -
my grey water tank is on the driver side ... am I misunderstanding?
2011 VW GTI
2009 Tacoma 4x4 TRD
