Old 06-12-2014, 12:26 PM   #1
Defrost adjustment knob not working
The little dial where I would adjust vent/floor/defrost/ etc is suddenly not working, any thoughts on why this might be?
Thanks,
C.
Old 06-12-2014, 12:29 PM   #2
rallypanam's Avatar
Re: Defrost adjustment knob not working
Thanks,
C.
I had issues on my old van on the fan dial.. corroded electrical connections.
Old 06-12-2014, 12:34 PM   #3
Jeffrey's Avatar
How are your brakes working? When my vacuum pump failed, the ventilation system was wiggy, too. I think the vents use vacuum to operate.
Old 06-12-2014, 02:26 PM   #4
Brakes seem to be working fine.
Old 06-12-2014, 02:41 PM   #5
fancypants's Avatar
Not sure if this describes your situation but this is what happened to me and how I fixed* it: http://www.sportsmobileforum.com/vie...hp?f=2&t=12582.
*: seemed to work as expected for the first couple months after the fix but I'm noticing that when I accelerate it is again sometimes switching to the dash/defrost vents. Haven't had a chance to troubleshoot it again.
KeVan: '06 E350 4x4 V8 "Transformer"
fancypants is offline   Reply With Quote
Old 06-12-2014, 04:33 PM   #6
Jeffrey's Avatar
If your vacuum pump is good (good braking) then check the rubber hoses for the vent mechanisms.
Old 06-13-2014, 04:51 AM   #7
What year, make and model are we working on?
Old 08-24-2014, 08:33 PM   #8
2007 E350 V10
Old 08-24-2014, 10:00 PM   #9
Most likely a rodent has eaten one of your vacuum lines.
Old 08-24-2014, 11:11 PM   #10
Pschitt's Avatar
Could also be the knob itself. Had to replace mine four weeks ago... But check the vacuum hose before to check that there is no leak.
Betsy
Dave&Di
Bearsmobile
mmocken
