Old 03-29-2015, 01:43 PM   #1
Battery cable routing from house battery to starting battery
Hi everyone,
I'm currently in the process of installing my Blue Sea ACR 7622 and was hoping that someone could shed some light as to what the optimal cable routing is from the starting battery to the house battery.
I'm using 2x 250A ANL fuses near each positive terminal to protect against shorts, yet still have enough capacity to use the house battery to jump the engine.
My battery box is installed into the floor, opposite of the aux. starting battery, and the 7622 is located a few inches behind the driver's seat. The cable will need to run from main starting battery to the 7622.
I see a couple options:
1. Follow the factory wiring down towards the starter, go back and across the transmission x-member over to the drivers side.
2. Go down from the main starting battery, below the radiator, and down the drivers side frame rail.
3. Run the cable above the engine with the wiring harness and drop it down near the brake booster.
4. My friend suggested that I run the cable directly to the battery positive on the starter, but I would have some difficulty finding a place to mount the ANL fuse, and it would be a pain to replace if it ever blew.
5. Connect over to the aux. starting battery instead. Not sure if this is kosher.
Thoughts?
2003 Ford E350 Diesel Cargo Van Conversion
dstupakov is offline   Reply With Quote
Old 03-29-2015, 06:21 PM   #2
Viva's Avatar
Re: Battery cable routing from house battery to starting bat
On my current (although non-SMB) E-350 (and on a friend's other-brand E-450), the cable runs "up high" across just below the hood seam (just below the windshield wiper grille things on the firewall), then down near the steering rod thingie (yes, I'm just full of technical terms today) and then back along the driver's side frame rail (where it goes back up into the coach, but in my case that is not through a stock van body). That might work on a van body as well though (at least the first part, if nothing else).
I didn't ever figure out the exact path of the SMB wire that ran aft, but it looked like it might have gone through the firewall and under the driver step-well cover?
One thing you might want to check is if the ANL fuse has enough AIC (ampere interrupt capacity) for your house bank. I see they are rated at 6,000 AIC (at least the ones on Blue Sea's website) and, depending on how large/what type of house bank you have, you might be over that. For example, two Lifeline Group 31 AGM's together have a short circuit rating of over 7,000 amps; two Llifeline Group 27's would run about 6,750 amps. The Blue Sea MRBF's are rated for 10,000 AIC. I have three Lifeline Group 31's (rated at a combined ~12,750 amps at short circuit), so even the MRBF wasn't quite high enough and I went to a Class T fuse (20,000 AIC) instead. Still at 250 amps.
(If you haven't used AIC, what guards against is, if you have a short, that the fuse holder itself does not fail - thus rendering the whole idea of the fuse somewhat moot. Today's larger battery banks can really be large power storage banks. If you have a bank whose short circuit rating is under 6,000 amps then the ANL would be fine.)
BTW, I have found that on the recommended Group 65 battery and with the stock hood (tested a 1997, 1998, and 2003), a MRBF/holder (Blue Sea) will fit on the positive terminal and not interfere with the hood. What I did was get a so-called marine terminal adapter (it's like a battery clamp mated to a stud), then put lug terminations on both the Ford wires and my wire going aft to the house bank; the cable going aft to the house bank sits on a Blue Sea MRBF that is on the post - this all clears the hood. The 10,000 AIC of the MRBF is adequate for the Group 65 AGM starting battery, and then you don't need to separately mount a fuse (and then I have the Class T fuse on the house bank where the higher AIC is needed).
If this isn't helpful..... feel free to ignore! (I'm not exactly sure what your setup is.)
Old 03-30-2015, 09:47 PM   #3
WVvan's Avatar
My house battery is in a different place than yours but here's how I ran mine.
http://www.sportsmobileforum.com/vie...p=93261#p93261
Open the pod bay doors Hal.
WWW.WVBIKE.ORG
