Old 06-20-2015, 10:29 AM   #1
LenS's Avatar
Did a Base Line on New House Batteries
To get an idea how long we can run our refrig (110v via converter) off of our new house batteries I ran a load test. Looks like 2 1/2 days with a 75-80F days and 60-65F nights. This base line will also give us a good reference to measure battery degradation by as they age.
Len & Joanne
The Green TARDIS
Old 06-22-2015, 01:16 PM   #2
rockbender's Avatar
Re: Did a Base Line on New House Batteries
Did you just use your fridge as the load? Are you just using the 0.1V as a constant approximation on your recovery voltage, or is that something you tested as well? I don't recall if you listed in your other post, but the new batteries give you 220 AH or so, right?
Off topic - did you put a rear sway bar on your Express?
Good work!
Josh
Old 06-22-2015, 02:56 PM   #3
LenS's Avatar
Good work!
Used my modified refrig (110v AC) with the 1000w TrippLite inverter powering if from the batteries as the load. At the 31 hour mark I ended the test. Measured to voltage on the house batteries then let them rest for 5 hours. They recovered 0.1volts after resting the 5 hours. I just off set the load curse by 0.1 volts.
Have not added sway bar to the Express. Suspension is OEM.
Len & Joanne
The Green TARDIS
Biggie
Berta
EB Van
ebflow
