Old 01-11-2015, 08:43 PM   #1
what wheels did you go with on your e350
Looking for ideas on wheels and tires for e350's
chavez is offline   Reply With Quote
Old 01-11-2015, 08:47 PM   #2
Pschitt's Avatar
Re: what wheels did you go with on your e350
Pro Comp 9x17'' with 35x12.5-17 tires... they have the highest load rate I've found...
Old 01-12-2015, 06:56 AM   #3
ATX Mojave teflon with Nitto terra grappler 285/70-17"..........pretty standard fare around here.....I like them a lot.
I have slight rubbing even after a trim job on the front wheel wells; my van is 4WD/lifted
Old 01-12-2015, 07:55 AM   #4
E350's Avatar
My wheels are Ultra Wheel Type 164 polished in 17" (See spec sheet) I have 9 of them. I guess they are good wheels, it was the wheel type chosen by the 4x4 converter.
File Type: pdf Ultra Wheel Type 164 - specifications.pdf (360.6 KB, 7 views)
Old 01-14-2015, 05:52 PM   #5
depark's Avatar
I went with Ultra Wheel 195 - Crusher 18x8.5
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
Old 01-15-2015, 11:12 PM   #6
ridintall's Avatar
Mickey Thompson Classic III powder coated black.
Make sure to check those load ratings when choosing wheels and tires.
http://www.mickeythompsontires.com/imag ... _black.jpg
ridintall is offline   Reply With Quote
Old 01-16-2015, 05:50 AM   #7
I have the above listed Mickey Thompson 17" black rims & Cooper Discoverer ST Maxx tires 285 x 70 x 17.
Very pleased with rim & tire.
Sheriffdoug
Old 01-16-2015, 10:06 AM   #8
Since my van was converted to 4x4 and has 8x170 bolt pattern, I went with F350 takeoff wheels/tires. Much cheaper than new stuff and well made/strong.
Old 01-16-2015, 11:21 AM   #9
WhitH's Avatar
17" Weld Racing forged wheels with 285x70x17 Goodyear Silent Armor tires. Mine is a standard lift height Quigley and this size seems to be about perfect. They don't ever rub but fill the wheel wells pretty nicely.
Sold 2005 E350 Chateau
Old 01-19-2015, 08:28 PM   #10
Have a 2011 e350. Not 4wd and don't plan on going 4x4. Am going to buy ATX mojave 17 inch wheels. But was wondering if or what offset would be correct on my van. The atx are 0 offset. Trying to see what stock is.
Thanks guys.
