07-12-2013, 10:42 PM
SOCAL build
After about a year of looking and talking to a few knowledgeable folks on here or recommended from here I finally decided to buy a 4x4 van as opposed to having one converted.
I bought a 2000 Ford F350 EB V10 with a Salem Kroger 4x4 6" leaf spring lift with 100k on it. I did spend a lot of time looking, I search about every site you can think of daily. In the end I had to fly 2 hours and drive 8 hours home to get what I wanted.
It is a beast, I have never been almost eye level with 18 wheelers before. It is also a bit skethy to drive, it wobbles but this will be fixed. It was also a work van so the interior needs work. Here are my plans as of today:
Here are a few before I bought:
07-12-2013, 10:52 PM
Re: SOCAL build
What I sold to buy "The Van". Big difference!
07-13-2013, 07:12 AM
Re: SOCAL build
Welcome to the gang! Good looking van. Your list will get a lot longer unfortunately, but it's a labor of love. Keep us posted as you can, and don't hesitate to ask questions. Lots of good info here.
07-13-2013, 09:33 AM
Re: SOCAL build
Interior cleaned out, now just need to find someone to weld the bolt holes closed that where drilled for the utility shelves in the floor.
07-13-2013, 12:00 PM
Re: SOCAL build
With your interior stripped out and sanded ... now is the time for sprayed in bedliner if you are going that route.
07-14-2013, 07:45 AM
Re: SOCAL build
Thanks 86scotty
Taylorvon, I was think that but I am leaning more towards the plywood rubber coin matting mod I have seen on here.
07-29-2013, 12:17 PM
Re: SOCAL build
I was on vacation for a week and while I was gone my brother-in-law completed the following:
Oil\Filter
Fuel Filter
Transmission fluid
Air filter
Spark plugs
Rear Breaks\Rotors and calipers
He still has to install the Pro Comp dual steering wheel stabilizer but needs to weld a mounting bracket.
Also the front rotors need to be machined out to fit. No sure what Salem Kroger does to the front end, best he could figure is a F-350 Super Duty, but some things do not fit right, they need some modification.
He will finish this work up next weekend.
All said and done $1100.00 in parts.
07-29-2013, 12:19 PM
Re: SOCAL build
Went to the body shop this week for a color sand\buff and have the door jams painted. They did a great job. This was a work truck so it needed it.
$650 but worth it.
$20 for the 4x4 stickers
07-29-2013, 12:25 PM
Re: SOCAL build
$1000 in misc parts have been pilling up so time to put them in:
4x4 sticker
Center console for dog house
Driver side interior door panel
Orielly's auto parts (misc supplies)
Home Depot spray paint
Window Driver side rear 40" x 12"
Front floor liner from FAMVAN
Fat Mat sound deading material x2 rolls
Window Passenger side 40" x 26"
Rear sill trim piece
Sliding door sill plate
Rear doors weather stripping
Home Depot Frost king Insulation
Passenger and driver side seat belts
07-29-2013, 12:26 PM
Re: SOCAL build
Rear doors with fresh paint\Fat-Mat and weather stripping
