12-05-2014, 03:09 PM
Dana 60 Gearing on '96 Ford 7.3L PSD.
Hi All,
I"m starting my 4wd conversion and will be getting a Dana 60 for it this weekend. Need to confirm the best gearing for it. The one I'm looking at is a 3.73. I'm planning on running between 285-295 size tires.
Description of the Dana 60:
- Ford ball joint Dana 60 off a 02 super duty.
- high steer knuckle.
- axle has 3.73 gears
- vented and slotted rotors
- heavyduty ballistic heim joints.
- Fox Steering stabilizer
Don't want to spend any more money than what he is asking ie. to swap out gears so if the 3.73 is a good match then looks like I will pick it up this weekend.
Suggestions comments welcome!
12-05-2014, 03:30 PM
Re: Dana 60 Gearing on '96 Ford 7.3L PSD.
Questions to be answered:
Towing? What size/ weight?
Mountains/ flat?
Altitude?
Configuration of rig as to boxes, load?
MPGmore important than acceleration?
Personally I like 3.55 to 3.73 for all round, but I am not towing and I like low revs on the freeway.
12-05-2014, 03:55 PM
No Towing.
Not sure of weight - it's standard sportsmobile so around 9-10K lbs?
I'm at sea level but go to Tahoe, Downieville, Yosemite, Death Valley a lot
Prefer MPG over acceleration. It has a TS performance chip on it it that I never use.
Looks like 3.73 will work?
Mountains/ flat?
Altitude?
12-05-2014, 04:08 PM
I would go w the 3.73's and the 285's. YMMV.
If you do not like it, the change is not that bad. What do you have in the rear now?
12-05-2014, 06:27 PM
Ok will go with that and see how it works out.
Not sure what is in the rear. Just got the van. It's got a camburg lift and running 285's now. Unclear whether one of the PO's changed out the gearing when they did the lift and bigger tires.
12-05-2014, 06:42 PM
Okay, but you going to need to know what gearing is on the rear, right? If it is not 3.73 then one of them has to change. If you have a 4.10 LSD rear end, then I would change out the front to match the 4.10 gearing. If the rear is 3.55, then I would change the rear to 3.73.
That information re: the rear spec is needed to move ahead.
12-05-2014, 06:48 PM
yes, I haven't decide yet whether I will swap out the rear and get a beefier rear end or keep the existing rear and match up the gearing or not.
Any thoughts on the adequacy of the existing rear end for a 4x4 conversion?
Just starting the swap process now and you will be seeing many posts from me i'm sure!
12-05-2014, 09:54 PM
rean1mator: What is your rear diff gearing? hint.....there should be a rear axle code on the data label in the drivers side door jamb.........
Also, is your rear end a full floater?
12-05-2014, 10:06 PM
I have a used set of 373 gears in great shape for sale, from a Dana 60 and 44. Heck, I'll about give em away.
Arctic Traveller
KC6TNI
2001 GTRV
Advanced 4wd
12-07-2014, 01:25 AM
Artictraveller: I would be interested in the Dana 60 3.73 ring and pinion.
