Old 03-09-2011, 09:03 PM   #1
oldbonesclimber's Avatar
Late Model Brake Upgrade
I decided to make the conversion to the Late Model 2008 and up Dynatrac Prorock 60 Brakes.
Several times I had wished I had more pedal when just trying to slow down for a turnoff and a few when it was almost panic. I like BRAKES. Sometimes even more than POWER. I never felt there was adequate brakes on this 10,000 lb vehicle and add to that the 35" Tires. I looked into the Brakeman Solutions during the build of the 07 but @$4000 I choose to save it for a later. Then the 08's came with Bigger Brakes. I thought that this could be the solution with simple standard Ford parts for ease in replacement When something goes South.
I had Dynatrac build me a List of the Parts necessary for the conversion.
1) New Steering Knuckles
2) New Ball Joints ( I'm glad I did the original ones only 34k miles were shot.
3) New Hubs
4) New Bearings ( I could have used the old ones but opted for New)
5) New Calipers
6) New Rotors
7) Tone Rings
8) Wheel Studs
9) Spanner Wrench ( to get the Axle nuts loose)
10) New Brake Lines
Total came to about $2800 w/freight Much Cheaper than a MINOR Accident.
I was in No Hurry to change over and it took a few days of checking it twice.
The real wait was having Brake Lines Fabed Up with the correct ends. SMB says they use an extention but since I had different Calipers than the 08's I just had some Stainless Lines made. DOT to boot. After doing the conversion It could easily be done in One Day if you have all the tools and parts. I did have to get an 1 5/16" wrench for the lower Ball Joint Nut.
The Results. Nice Brakes The pedal feels like it should. It is still a 5 Ton Truck but is MUCH MUCH Nicer. I'm having a little trouble uploading some images and don't have too many as I have a hard time touching my camera with GREASEY Hands.
Here are the steps if I remember.
I am assuming the obvious.
1) Remove Front Wheels
2) Unbolt Caliper Brackets ( Have a LARGE Breaker Bar, These babies are Glued in) and Hang
Caliper aside
3) Remove Warn Hubs
4) Unbolt Axle Nuts Spanner Required
5) Remove Rotor and Hub Assembly
6) Remove Spindle Assembly
7) Slide Axle out Carefully
8) Disconnect Tie Rod
9) Loosen Ball Joints and Remove Knuckle Assembly
Reverse procedure for reassembly.
Attach Brake line and Bleed Brakes.
Original Brake Assembly at the start.
Axle Tube Assembly with knuckles and axles removed.
New Brake Assembly Installed
New Caliper Assembly showing different location of Brake Line Attachment.
Brake lines were fabed up by Crown Performance and are stainless DOT with the correct ends.Not Shown. I had to do a small modification to get them to mount but all came out nice.
The abs sensor is different than the 08's but will attach on the old spindle and the outboard slinger is of a different stlye but the original one will work.
Hope this helps and if anyone needs me to get the parts for them from Dynatrac I would be happy to and it would help keep my relationship with Dynatrac.
Paul
Old 03-09-2011, 10:04 PM   #2
Roonie's Avatar
Re: Late Model Brake Upgrade
Great write up and good time to upgrade to the new HD ball joints from dynatrac.
http://www.dynatrac.com/products_pro...alljoints.html
and maybe even their new hubs?
http://www.dynatrac.com/products_dynaloc_page.html
Did you get all the parts from Dynatrac? or did you get some parts from the Ford dealer?
Old 03-09-2011, 10:23 PM   #3
I got all the parts from Dynatrac. And yes the rebuildable balljoints are nice, Just add about $550 and so are the Hubs, add about another $550 and then upgrade to the 32 spline axle ends and another $400. Just where does one stop? I think the Brakeman has better pads and rotors also so you may want to get them there, how much ? I had to draw the line somewhere.
Paul
Old 03-09-2011, 10:26 PM   #4
Awesome write up, thanks for posting. This gives me some real inspiration.
webbmac is offline   Reply With Quote
Old 03-10-2011, 10:26 AM   #5
Roonie's Avatar
I am also assuming this conversion can only be done with 17" wheels and will not work with the 16" wheels?
Old 03-10-2011, 05:27 PM   #6
You are correct. It requires 17 inch wheels. I've always had them so I didn't even think about it.
Paul
Old 03-10-2011, 06:00 PM   #7
I am running power stop brakes on all 4 of my 4x4 vans and are 2 wheel drive vans and we had all rotors cryod to stop the rotors from warping . I can lock the brakes up on them all. And we pull 6000 # trails behind them.
Chimneyman is offline   Reply With Quote
Old 03-10-2011, 07:18 PM   #8
Chimmney,
What size tires are you running?
Old 03-11-2011, 11:31 AM   #9
Originally Posted by oldbonesclimber
Chimmney,
X2 plus how heavy are your vans?
Old 03-15-2011, 05:23 PM   #10
On my expedition van Im running 35" tires 16" wheels . weight 9600 .
My other vans are 33" tires and the are loaded to about 10,500 with tools and ladders, and we pull 14' tandem enclosed trailer weight is 7200. we dont have any problems.
Esme
Amy V
Loud Mobile
pinz712
