Old 11-08-2013, 01:23 AM   #1
AndrewST's Avatar
E350 Ford frame from a dually ambulance
Hello
Am thinking of a project based on a cut out cab from an ambulance and have a basic question...
Once the cab and the ambulance box are removed can one install a regular EB van body on the frame?
Are all the E350 frames the same?
Andrew
AndrewST is offline   Reply With Quote
Old 11-08-2013, 07:52 AM   #2
Re: E350 Ford frame from a dually ambulance
Check the wheelbase. There are several different wheelbases available on cutaways. If the wheelbase is the same, look for an extension on the rear of the frame.
Old 11-08-2013, 10:43 AM   #3
If it is an E350, maybe. Those come in 3 wheelbases and the short one is 138" just like the vans.
E450s only some in 158" and 176" (and often is stretched longer up to 223").
I have seen one E350 wagon body dropped onto an E450 frame. He cut the front doors mid-way and spliced in to the cutaway cab. It looks factory when he was done, kind of like an extended cab pickup. They even opened. He obviously was good at body work though.
I've though about doing the same (those chassis are cheap!), but my approach would simpler. I would cut the donor body at the B-piller, and fill the space with a cab extension.
http://www.cabbacks.com/about.html
Old 11-08-2013, 10:45 AM   #4
And yes, the frames are identical except for wheelbase, and the lack of bumper-mount end-plates on the cutaway.
Also, cutaways have a rear tank, but you can add a rear fuel door to a van body (Ford sells a kit for wheelchair vans) and you can even add a mid-ship tank and have 2.
Old 11-12-2013, 12:20 AM   #5
AndrewST's Avatar
Thank you for the answers and the link.
Old 11-14-2013, 06:54 PM   #6
I'm driving a e350 cab and chassis now.
It is the short 138 inch wheelbase.
I think that you could but a van body on it.
I plan to put a small mini-mod box on the back.
cjken is offline   Reply With Quote
Old 11-16-2013, 02:50 AM   #7
AndrewST's Avatar
Thanks for sharing your project
Old 11-19-2013, 06:58 PM   #8
Bones_GSXR's Avatar
I like how Chris (Ujoint) did his using a different camper with the Chassis Cab. Also look at these to convert to a truck type cab. the make them in lots of lengths too.
