Old 02-17-2014, 05:37 AM   #1
4MacFam's Avatar
Off road Trailer. Anyone have an Xventure?
Been dreaming about an off road trailer and ran across these. http://www.schuttindustries.com/Consumer.aspx Emailed them about pricing without looking where they're located and found out they're in WISCONSIN. I know where I'll be stopping on my next trip up north (only 2 1/2 hrs). Want to put some kayaks on top and the bikes off the back. Motor cycle or ATV inside might be fun too.
From them:
XVENTURE XV-2 ships with standard 6 lug hubs to match your domestic vehicle.
Below is the pricing information you requested;
Any customization you may want is available upon request. Simply tell us what you need and we will quote you on the modifications.
We recommend that if you haven't already, watch this video on the manufacturing process for XVENTURE http://www.youtube.com/watch?feature...&v=ZPxK6Mr0LLQ
All information about the product is on our website at http://www.goxventure.com and all the latest images and video are available at http://www.facebook.com/xventuretrailers
For a limited time we are including the Elevating Cargo Rack System at no additional charge. This is a $1595 value.
The base model XVENTURE XV-1 trailer is $11,995 which includes the following:
XVENTURE Trailer – All Aluminum Construction, Includes the following plus standard trailer amenities such as front wheeled jack and rear adjustable vertical stabilizers, etc..
Fully D.O.T. compliant in all 50 states.
3 Piece Step-Style Fenders
Fender Receivers – For Accessory Attachments
Large Front Storage Cabinet – 62 wide x 22 tall x 19 front to back. All Aluminum.
Multi-Axis Max Hitch
Electric Drum Brakes
Dual independent manual brake controls
Emergency Break-Away brake actuator
Through-Drawbar IVC Cable with right angle cover plate incorporating a metal mesh Cable Stretch Eliminator Sleeve and Metal IVC Plug
Reverse Lights / Area Lights – Super bright white 24 device LED modules – These turn on when the tow vehicle is placed in reverse, and are also able to be switched on from the power distribution control center to act as large area illumination lighting.
Power Distribution Center - Completely wired with 6 fused switchable supply ports - This allows you to integrate up to 6 electronic accessories like additional lights, compressors, pumps, charging units etc., to a fused circuit that is remotely switchable from the control center switch block.
Wiring harness runs through chassis tubes for optimal protection
Exterior mounted weather proof 110V Shoreline-In receptacle
Exterior mounted weather proof 110V output receptacle
Exterior mounted USB and solar panel Input/Output ports
50 AH Power Generator with integrated 110V inverter, and charger. - We have optional GoalZero Yeti power systems available including Solar Panels.
Cargo bed mounted 12VOLT receptacles - Receptacles on either side of bed at rear
Lighted license plate mount on tailgate
Truxedo Toneau Cargo Bed Cover
Poly Urea (Line-X) Coating - Cargo Bed Interior and Front Exterior Wall, Chassis, Fenders, Storage Cabinet
3M Body Wrap in the color of your choice - Exterior Side Panels (Sides and Tailgate) Some Graphic Design implementation included.
2: Tires and Rims (Includes Spare) 16 x 6 6-5.5
2: Steel Rims with LRR (Low Rolling Resistance) LT 7.50-16E Tire
Rear 2" Accessory Receiver
2: Rear D-Rings – These are Air Lift Rated
10 Year Warranty on Chassis
Any color your need is available and included with the base model. All we need is your manufacturers color code.
Available Options;
22 Gallon Water Tank – mounts under cargo bed with Armor Housing and Line-X coating - $650
Water Pump – Included with Tank
Full Length Aluminum Folding Galley Table - $350
All Stainless Drop-In Propane Cooktop $250
Sink Basin with Hot and Cold Running Water - $300
Propane System – Includes Mounts, Aluminum Cover with Line-X Coating – 20LB Tank – All Stainless Mess covered lines - $250
Water Heater - $400
Shower Privacy Enclosure - $150
Latrine with Enclosure - $150
Elevating Cargo Rack System - $1595. $1500 if ordered with trailer.
Roof Top Tents – From $995 - $3500 depending on model.
Awning 78ft - ARB 8ft Model 2500 - $250
Dual Articulating Solar Mount with 2 Goal Zero Bolder 30 Panels - $750
Unit are in-stock ready to ship.
We also have the XV-1 hitting the market in a few weeks which is essentially an entry-level version of the XV-2 without front Storage Cabinet, Line-X coatings, or 3M Wrap. However it is completely modular and all of the above listed features and accessories for the XV-2 can be easily added to it which are plug-and play to the end user. Street price should be around $6500.
Steven McKenzie
Madison, WI
2013 E350 EB-44, V10 6.8ltr
Toyo LT285/70 R17
Old 02-17-2014, 09:17 AM   #2
Re: Off road Trailer. Anyone have an Xventure?
The XV-1 is priced about the same as the SMB trailer was priced - and it seems much better engineered. I like it.
Old 02-17-2014, 10:49 AM   #3
E350's Avatar
I have a 1950's Dodge 1/2 ton pickup bed utility trailer. It has served me well for transporting gravel, firewood, slash, doing dump runs, and moving furniture, but I have day-dreamed about welding a tandem axle utility trailer of approximately the same relatively-small size but with more weight-bearing ability with kind of a "transformer" expandable nature.
Thank you for posting the link to Schutt Industries. Their products are just brilliant. Their products materialize the brilliance of and the refusal(s) to compromise of the brain(s) of the designer(s). Looking at their products, I think "Howard Roark," and am humbled.
Schutt Industries website has added features to my still-daydreamed proposed transformer utility trailer.
Old 02-24-2014, 09:46 PM   #4
Christopher Thwaites's Avatar
Schutt makes some nice Sch*tt!
Brad are you watching?
Chris/Ruth
2016 MBZ Sprinter 144" 4wd.
DIY
07 BMW 525xi wagon
Christopher Thwaites is offline   Reply With Quote
