Old 01-28-2015, 08:24 PM   #1
oldbonesclimber's Avatar
For Sale 2007 Ford Dana 60 Semi Floater 4:10 LSD
Taken out of my 2007 SMB 4X4 . Dana 60 35 spline? Single Floater 4:10 and LSD. Will bolt right in to any e350. Needs shock mounts repositioned as this is off a 4X4. Brakes are very good but rotors could be resurfaced due to surface rust.
Paul
2007 RB50 6.0 PSD Walker Evans Streetlocks, 305X70X17 Terra Grapplers Custom Aluminess Roof Rack, ETC ETC
oldbonesclimber is offline   Reply With Quote
Old 01-28-2015, 08:33 PM   #2
Re: For Sale 2007 Ford Dana 60 Semi Floater 4:10 LSD
Just FYI...
E350s have 32-splines. 35-splines were only in the E150.
Also, a 2007 6.0 rear end will not fit any '05+ van with RSC including all 5.4L wagons, or any van starting in '08, due to the outboard wheel speed sensors. The RSC & '08+ vans also have independent rear brake channels, instead of branching from a single rear line like the older versions.
Old 01-28-2015, 10:11 PM   #3
Thanks for keeping me honest. I thought the sf 60's had 35 splines as I've read in some other posts?
Whatever, it would still make a great upgrade to a 2wd with oversize tires.
Paul
Old 01-28-2015, 10:18 PM   #4
Originally Posted by carringb
Just FYI...
A 1 ton has 32 splines and a 1/2 ton has a larger axle with 35 spline? Something is wrong there me thinks.
2005 E350EB, 6.0, UJOR 6" lift, 35" tires and more.
Zuma is offline   Reply With Quote
Old 01-28-2015, 10:38 PM   #5
I thought the semi-float had 35 spline and the FF had 32 spline axles? Which is counter-intuitive but since the FF doesn't support the weight on the axle they are 32 spline?
2011 VW TDI Golf for hwy fun
Old 01-28-2015, 10:56 PM   #6
Oops that is correct. The SF is 35, while the FF is 32.
Old 01-28-2015, 11:08 PM   #7
1der's Avatar
Do you have one of those charts for the 2002 and 2003 model years? Lots of good info there!
Anyone have an extra or PDF version of the factory repair manual (full set) for these for 02 and 03? I am interested in purchasing one, especially for the '02 w diesel supplement. Thanks!
Old 01-29-2015, 02:05 PM   #8
Ford has the '03 specs up still, but not the '02 specs:
https://www.fleet.ford.com/truckbbas...003/specs.html
Note: even though it says full float for the extended vans, I know that is not the case. Starting in '03 SF pretty much came on all vans, except for a small handful of EB wagons, but even most of those got SFs in '03.
TBD
thatsandrea
Dusty
capnkurt
