02-01-2015, 07:04 PM
Sold - 2006 Ford E250 5.4L V-8
More Photos in Galley
Vehicle Chassis
2006 Ford E250 RB 5.4 V8
Vehicle Height 83 to Top of Roof and 85 to Top of Awning Housing
Oxford White with Clear Coat (van kept covered and waxed twice a year)
54,000 Miles (well-maintained with oil and filter changed every 3,000 miles)
14 MPG (average over 30,000 mostly highway miles)
35 Gallon Gas Tank
Automatic Transmission with Overdrive
Limited Slip Differential
4 Wheel ABS Disc Brakes
Michelin LTX 245/75/R16 MS2 Tires (New 3/27/14 @ 44,667 miles excellent tires for this vehicle)
Polished Aluminum Wheels
Chrome Bumpers Front and Rear
Halogen Head Lamps
2 Factory Receiver Hitch with Electrical Wiring
Engine Battery (New 7/12/14 @ 41,589 miles Group 65)
Factory Air Conditioning
Power Windows, Locks, Side Mirrors
Tilt Steering Wheel/Speed Control
Factory In-Dash Clock/AM/FM/CD Player with Front, Rear, Side Door Speakers
4 Cup Holders and Lower Storage Bin in Cab Area
Sportsmobile Equipment
Seats 5
Sleeps 4
Front Driver and Passenger Captains Seats Swivel 180 Degrees
Modified Sportsmobile RB-30 Floor Plan Walk Through Front to Back
Penthouse Top (extends to windshield storage shelf above cab with top up) Manual
5 Penthouse Windows all with Screens, 4 with zippered Clear Vinyl Windows and Roll-Down Shades
One-Piece Penthouse Bed (40 X 68)
Goucho Couch Converts Into bed 44 X 68 + 9 Extension = 77
Dove Grey Cabinets
5 Storage Cabinets, 4 Drawers, 1 Full-Height Pull-Out Pantry, 2 Over-Counter Storage Bins, 1 Flip-Up Counter Extension, and 1 Flip-Up Gaucho Side-Table
Magazine and Map Holder
3 Retractable Hooks
Under-Floor Storage in Rear
Drop-Down Task Tables and Storage Compartments in 2 Side and 1 Rear Door
Overhead Storage in Cab Area
2 Illuminated Vanity Mirrors on Sun Visors in Cab Area
2 Large Storage Pockets on Back of Front Seats
1 Storage Pocket on Rear Door
Electric Flush Porta-Potti
3 Sliding Windows with Screens and Day/Night Shades
All Rear Factory and Sportsmobile Installed Lower Windows Tinted
Front, Side, and Rear Privacy Curtains (Reflectix interior window panels cut to size for windshield, cab, and back windows for hot/cold weather use)
Exterior Vinyl Cab/Windshield Cover for interior sun protection (New used once)
Rear StarCool Air Conditioner with Thermostat
Microwave Oven Dometic 700 Watt .7 Cubic Foot
2 Way 12 Volt DC/120 Volt AC Norcold 3CF Refrigerator
2,000 Watt Inverter/Converter/Charger with Remote Monitoring Panel
2 Lifeline Group 27 100 Amp-Hour AGM Batteries (New 7/11/14 @ 41,589 miles)
120 Volt AC 30 Amp Electrical System with GFI Protection
Indoor/Outdoor Digital Thermometer
120 Volt AC 2.5 Gallon Water Heater
10 Gallon Fresh Water Tank with 12 Volt Shurflo Water Pump
Stainless Steel Sink with 8.5 Gallon Grey Water Holding Tank
12 Volt 2 Speed Oscillating Air Circulation Fan
3 12 Volt High/Low LED Lights
3 12 Volt LED Reading Lights
1 12 Volt Florescent Task Light
CO and Smoke Detectors
Removable Dining Table with High and Low Pedestals and tripod base
Matching Grey Upholstery Throughout
All Cables and Hoses to Connect to Shore Water, Power, and Cable TV
TV/DVD/CD Player 12 Volt Coby TF-1570 15 on Articulating Tilt and Swivel Arm with Tie-Down Strap
Cable TV Exterior Hook Up and Interior Wiring In-place
Rear Radio Power Selector Switch
Exterior 120 Volt Outlet
Exterior 12 Volt LED Porch Light
Door Talon (to hold rear side door open when parked on a slope)
Fire Extinguisher
All Electric Sportsmobile Conversion (no propane tank or propane appliances)
Additional Equipment
72 Thule Roof Rails
Thule Rooftop Carrier Bars with Locks
Rear Door Mounted Ladder
Rear Door Spare Tire Mount with Full Size Never Used Spare Tire and Cover
8X10 Fiamma Awning (Added 2010)
Fitted Fabric Van Cover (New replacement) after 5+ years)
Custom Locking Receiver Hitch Carrier for Honda 2000 Watt Portable Inverter/Generator
2000 Watt Honda Inverter/Generator with Cover
120 Watt Portable Zamp Solar Panels with Case and Exterior Zamp Connection Port
Custom Straps for Securing Cargo Throughout
Full All-Weather Rubber Backed Fitted Carpet to Protect Marine Vinyl Floor
Carr Super Hoops Driver, Passenger, and Side Door Hoop Steps
Jeff and Janna
2014 Brilliant Silver MB Sprinter 3.0L V-6 High-Top 144 WB Modified RB-153S Espar D-5 SC Hydronic 200W Zamp Solar
SOLD 2006 White Ford E250 5.4L V8 4X2 RB-31 Modified, PH Full Length Garageable
02-01-2015, 07:55 PM
Re: 2006 Ford E250 5.4L V-8 $39,950 54,000 Miles
Sorry to hear you guys are selling! Good luck.
02-07-2015, 02:43 PM
Nice Van.
Saw it has a roof rack. Does it have the power pop up?
Sent you a pm.
02-07-2015, 09:40 PM
It is a manual Pent House Pop Top - not electric. The roof has the rails in place and the actual racks will be included in the sale.
Jeff and Janna
02-08-2015, 02:26 PM
Shore power or campground hook-ups are required to power the 2 1/2 gallon 120V electric water heater which is located in the cabinet below the sink, to run the microwave oven, and to use the StarCool air condioner.
There is NO onboard propane tank installed so NO built-in furnace or stove.
Jeff & Janna
Jeff and Janna
02-08-2015, 04:48 PM
But the Honda genny can be used to run the Starcool, water heater, etc., right?
02-08-2015, 06:39 PM
The generator will charge the batteries. The water heater and the StarCool are both huge battery drainers so expect to have to run the generator a significant time to replenish.
Jeff & Janna
Jeff and Janna
02-08-2015, 09:06 PM
Could you add a few interior photos?
02-08-2015, 10:57 PM
Great looking van! I noticed that the penthouse top goes all the way up to the front windshield. Did you special order it this way? There has been some mention where people wished SMB offered this, but this is the first factory installed top that I've seen that goes to all the way up to the front. Are the latches on the exterior to hold the top down? Also, what do you use the extra space above the cab for? Storage when the top is up?
02-08-2015, 11:30 PM
^^^This!
Greg
New van: 2003 E250 EB10
