Originally Posted by vandiesel
Thanks Joe! I'm going to put some miles on it today and make sure I'm solid.
I’d drive it the same number of miles as the original fluid, pull a sample of the 75/250 fluid and let Blackstone compare the contaminates in the original vs 75/250. You’ll then have a 3rd party definitive look to see if there’s a actually difference or are you masking something that will just rear it’s head later.
Slightly different in that my OEM locker worked fine but I had a rear diff in a
brand new FJ Cruiser that went from fine to bad noisey whine in the first 2500 miles, long story short Toyota would do nothing, saying it was within acceptable levels. (Interestingly they replaced the driveshaft ? while they had it and no one would ever tell me why, no bulletins or recalls) I pulled samples and ran analysis on original fluid and 3 additional 20k mile fluid changes w/OEM fluid after that. Blackstone documented clearly the ppm of iron were way out of range compared to other FJs they had done as well as against their universal averages, though the ppm came down each time. I sent copies to Toyota and dealership mgr, Toyota has still done nothing and I’m sure at this point they never will, probably assuming I’ll just eventually trade it away at some point but the vehicle it replaced I put 377,000 miles on so I do tend to keep things. If nothing else it’s nice to prove your right even if you can’t make them do anything.
