Originally Posted by ohsix
I think the advantage of converting with the bracket is it's easier to change shocks. On the driver's side, it's 1/16 turn at a time on the stem because the rear AC lines don't leave much room to work.
Hey ohsix, when you pulled the old shocks off and put the adapters on, what did you do with the stock bushing? Did you leave it or cut it out?
I have that same adapter kit, and it looks like i need to cut out the old bushing, but don't want to be destructive and then regret it.
EDIT :
Found how Ujoint does it:
https://youtu.be/KI2WSHMAJNQ?t=699
