Old 07-07-2017, 02:44 PM   #11
I love the Fox shocks that I have. I had always been partial to Bilstein or Koni and was frankly leery of Fox, as I considered them more of a shock for rock crawlers and the like. I replaced the 6 Bilsteins on my van with 4 Fox dampers and could not be happier. Great rebound control along with an improved ride.
This past Sunday, I was driving a 1-ton DRW pick-up truck with my daughter behind me in the E-350. Both vehicles were at their respective GVWR. We hit one particularly bad frost heave that had the pick-up bobbing up and down and essentially out of control for a couple hundred feet. I called my daughter on the CB radio to ask how things went back there. She did not even know there was an issue. I'm putting new dampers on the pick-up today; they'd be Fox units if they were available for the application.
A couple notes of caution:
1.) If you have a Transfer Flow 46-gallon fuel tank, installation is a a little more complicated. Fox puts the body of the damper on the top for some reason, whereas the OEM and Bilstein mount that part on the bottom. To clear the fuel tank, I had to clearance out the driver's side upper mounting hole in the cross-member by about 1.5" and then weld a re-pad for the new upper mounting location. Not a huge job, but not a bolt-in either.
2.) Unless you have a bone-stock SMB, carefully measure the rear shock length at full droop and calculate the full compression distance. My rear suspension has additional overload springs and a couple other mods that made the standard RIP rear shock 2" too short. It provided the opportunity to get those lower rear shock mounts up higher like I always wanted, but it was a bit of additional work as well.
2003 E-350 EB
7.3L
Quadvan 4x4
beaker is offline   Reply With Quote
Old 07-08-2017, 09:00 AM   #12
stikine's Avatar
Thanks Beaker for the heads up as my Fox Shocks from Agile should be here later in the month. I do have the Transfer Flow 46-gallon fuel tank, but my 2007 E-350 6.0l is a "bone-stock" SMB conversion (understand you have Quadvan). Other posts that were SMB conversions and replaced OME shocks with the Agile Fox shocks didn't mention the install problems you had, so hope everything goes OK.
2007 SMB White 4x4 RB50 6.0l Diesel PH, Toyo 295/70/17 M/T E
https://www.ecotonephoto.com/
stikine is offline   Reply With Quote
Old 07-08-2017, 11:16 AM   #13
ShuttlePilot's Avatar
This thread needs a picture.
Sounds like you and John were able to connect.
-Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
Old 07-08-2017, 03:46 PM   #14
achop's Avatar
Originally Posted by MadScience View Post
Any reviews on just the stabilizer?
I'm curious as well.
Muy Bonita - 2000 Ford E-350 V10 Quigley with 285/75 R16s, SMB-West RB50, manual PH
achop is offline   Reply With Quote
Old 07-08-2017, 04:07 PM   #15
shenrie's Avatar
I put the fox stabilizer from agile on a few years after the rip shocks and front springs. Definitely an upgrade over the spent rancho stabilizer that was on it.
Old 07-22-2017, 02:56 PM   #16
Hi,
I recently bought 2007 Ford E350, V10 SPORTSMOBILE Conversion and am considering putting Kelderman Air ride suspension on the rear & Fox 2.0 shocks on the front.
Any thoughts on this?
Stacy is offline   Reply With Quote
Old 07-22-2017, 11:40 PM   #17
MadScience's Avatar
I'd stick with using shocks in the rear as well.
Edit, sorry, wow, what I just wrote sounds terrible, but I actually don't understand the previous post.
Are you going to use fox shocks all around plus the air ride? The air ride is a suspension, i.e. spring replacement. I don't think it replaces the shock absorption portion of controlling movement at all.
Old 07-23-2017, 01:46 AM   #18
Originally Posted by Stacy View Post
Hi,
I used to have a Provan Bengal Tiger (F-350 or Silverado 3500 based) and was considering putting a Kelderman on it. The folks at Provan told me that it was overkill for the Bengal and only appropriate for a Siberian (F-550 based). I have no other experience with this and am just passing on what they told me.
Old 07-24-2017, 10:52 PM   #19
bolty's Avatar
After about 10,000 miles my 2011 E-350 was wandering down the road pretty good. I first tried the SMB Fox Steering Stabilizer which didn't help. I then took it to Agile. Ramsey correctly guessed it was worn bushings in the rear springs which introduced enough play that my van was always wandering. Problem solved. While I was there I had Agile put on some custom springs and Fox shocks front and rear. The rear is much, much better. The front, not so much...
bolty is offline   Reply With Quote
Tags
fox, shocks, shox, steeing stabilizer
Ford
fabtechmfg
Yeti
ACTNPKRYETI
