Old 10-23-2015, 10:36 AM   #21
Re: Irritating rattle from 4x4 shift levers
I'm betting the noise is coming from the pivot in the shifter , pull the boot up and see if there is a bolt to snug up or a way to get a washer or some plastic isolater in there.
I just built a shifter for my van and it's pretty basic how they function
Johny5 is offline   Reply With Quote
Old 11-12-2015, 08:33 AM   #22
stanrich's Avatar
I have 120k on my 2003 Sportsmobile 4x4. I too have been irritated with the rattle, but not thinking much about a mechanical failure or mis-adjustment I simply looped my baseball caps(2) over the knobs and it seems to stop the rattle enough not to notice. Another fix I have used is a small strap that I can tighten if necessary.
Stan Richards
2003 EB-50 7.3 PSD SMB 4x4
stanrich is offline   Reply With Quote
Old 11-12-2015, 09:05 AM   #23
haywoodphotomaccom's Avatar
I use a tennis ball between the shifter knob and seat......works perfect unless you have a dog get in the van and they go for it....
Brent
2006 Quigley V-10 (Sold)
Old 09-20-2016, 10:07 AM   #24
geoffff's Avatar
Just noticed this thread...
My shifters have rattled like this since day one, driving my new Sportsmobile out of Fresno.
The fix I've used successfully since then is to keep a rubber band strung between the levers. Works great. I replace the rubber band every few years.
2004 Ford, SMB 4x4, RB-50
Old 09-20-2016, 09:45 PM   #25
Smile
Hey Steve,
Did not read all the replies so my answer may have already been mentioned.
Anyway, I have the same issue in my 2010 EF350 EB. After much analysis and thought I figured a rather technical fix. I wedge a tennis ball between the levers. Problem solved!
Jim
JTPhoto is offline   Reply With Quote
Old 09-22-2016, 10:27 AM   #26
I have the same issue with my Quigley.
jjuan is offline   Reply With Quote
