Old 11-28-2021, 12:07 AM   #1
Longer Drag Link Adjusting Sleeve for E-Series 4x4?
I've been searching here and other forum trying to find a thread where someone talked about replacing their Drag Link Adjusting Sleeve from a stock F-Series to an aftermarket one that was slightly longer to engage the threads better on a F-Series drag link under a E-series 4x4 van conversion due to the wider frame rails. Does anyone know who that mfg was of the longer adjustment sleeve or have a link?
ATNC325 is offline   Reply With Quote
Old 01-24-2022, 04:28 PM   #2
TomsBeast's Avatar
There might be a longer threaded tie rod end
Old 02-01-2022, 09:55 AM   #3
Ran across this one but haven't tried it yet....
MOOG DS300041 Drag Link = 37 inches stud center to end (looks to be probably a bit too long or at least minimal room for adjustment one way.
MOOG DS300040 Drag Link = 34.16 Inches from Stud Center to End (the one I'm currently running)
Old 02-08-2023, 08:25 PM   #4
MadScience's Avatar
This is probably a bit late for OP, but since the DS300041 length info may solve my problem, I should share that I have a MOOG DS80749 here and it's 34 1/2" in length, measured from the center of the stud to the end of the threads.
I'm pretty sure these are all 1" diameter with 1-16 threads. I don't know if the stud diameter ever changed.
Old 02-15-2023, 08:53 PM   #5
MadScience's Avatar
This is the MOOG DS80749 measuring 34 3/4" from center to end
and the MOOG DS300041 measuring 37 1/4" from center to end
They are both 1" diameter with 1-16 threading.
Edit: the MOOG DS300041 does come with the anti-rotation bar as well.
