Old 10-07-2020, 11:58 PM   #361
good deal , the power is almost the same , ill will hook my camper up this weekend weighs about 4500# loaded . should be fine . I know the haters will complain but im happy and thankful for what i got.
motovan85 is offline   Reply With Quote
Old 10-08-2020, 12:00 AM   #362
Yeah man -- you can't please everyone, so you got to please yourself!! Great job on getting the job done.
I have my axle hanging but still need to set the trac-bar, draglink, sway-bar, dual stabilizers and now my SumoSprings!!
winnievan is offline   Reply With Quote
Old 10-08-2020, 12:06 AM   #363
i didnt use the drag links or the swaybar, you might try it first and see how it handles , we will see if anyone chimes in ?
Old 10-08-2020, 12:13 AM   #364
Do you mean the sway-bar links? I probably will leave the sway bar off for a bit -- but without the drag-link you wouldn't be able to steer -- so I don't think you actually left that off!!
:-D
Old 10-08-2020, 12:31 AM   #365
copy sway bar links hahaha
Old 10-19-2020, 11:35 AM   #366
what size wheel and tire did you end up using? are you happy with the clearance?
i also have the 5.4 e350 2013 and in the process of mg install.
amamdani is offline   Reply With Quote
Old 10-19-2020, 05:07 PM   #367
im running 2015 20s factory takeoffs for now, they are close to 34"s no clearance issues but i did move the front bumper out about an inch and trimmed the lower black plastic faring . I will go with 35"s after all the mod work is complete !
Old 10-20-2020, 08:27 PM   #368
Brake Line Advice
HI all, My 6.0 long block is on the way, so I decided to tackle the MG kit while waiting.
Any advice on how to button up the front passenger brake line and abs lines?
The trimming removed the mount points for the brake line, and I am curious how others dealt with this hard line.
desertsherpa is offline   Reply With Quote
Old 10-20-2020, 08:43 PM   #369
Obes's Avatar
Gently reshape the hard lines with your hands and drill new holes in the remaining lip area to reattach the mounting clips. Just take your time and do a little at a time. I worked the lines from each end near the frame rails to help with the manipulation at the trimmed area of the cross member.
Obes is offline   Reply With Quote
Old 10-20-2020, 08:47 PM   #370
Thanks for the reply and advice. Currently the line is too tall now, and would like to keep it mounted in the stock clips on the drivers side.
Jnlola
jnlola
TumbleWeed
Sarah
