Not sure if it helps since it seems every van is different but on my 2005 SMB there are 4 lines. The F series kits I looked at for fit have 3 lines. The 2000 & up E350s require an additional brake line for the rear drivers side brake caliper instead of one extended line for the rear.
At Crown's suggestion for fittings we went with a straight on top and 90deg bend on the front calipers. For the rear 2 lines we did a 3/8-24 Female x 3/8 Banjo at the calipers with a male on the left driver side to connect directly onto the TEE. The rear right had a female to connect to the hardline.
2011 VW TDI Golf for hwy fun
