Originally Posted by E350
MG: Can I ask you how the house battery/alternator/charger/inverter was set up?
According to the instructions...
Oh...did you want a better answer than that? Ok. Scalf77 can chime in here too in case I miss something. Greg was a HUGE help in laying this out and getting the systems installed.
here's a list of components in the system:
-4 big Optima Batteries on the rear skid (see pics earlier in this thread). 300A fuse right off the batteries then a run of wire up to the driver side just in front of the wheel well. A Positive and Negative bulkhead connector goes through the floor in an accessible spot. Then on the inside, the both leads go to buss bars.
-The inverter is a Promariner True Power Combi 2000PS.
http://promariner.com/products/marine-c ... r-combips/
Inverter connected to the buss bars mentioned above.
The shore power plug is mounted below the bumper, opposite the trailer plug then a run of wire up to approx. the same location as the battery cables to another pass-through. House wiring is then split off into a fuse panel from Paneltronics
http://www.defender.com/product3.jsp?pa ... 4&id=51318
Microwave, fridge and a single GFI outlet are hard-wired into this panel. Fridge is also wired to 12V fuse panel that is fed from the buss bar (complete with big fuse to protect the panel and individual fuses to protect each circuit). fuse panel and main 12V fuse are from Bluesea systems. The inverter has a remote control panel that is mounted under the rear seat next to the outlet and house fuse panel.
-The starter batteries and house batteries are linked via the dual battery system from IBS.
http://ibs-tech.ch/en/products/dual-battery-system.html
Control panel is mounted on the dash just to the left of the stereo. The IBS system is also complimented by the Relay Booster Module
http://ibs-tech.ch/en/products/dual-bat ... modul.html
Everything here is top quality stuff in my opinion. Some of these components are from sponsors and were decided on well before I got involved in the project so I can't answer any questions about why they were chosen. I can say that hooking them all up was simple (once Greg came over and talked me through it
) and everything works perfectly. Wiring the power mirrors was more difficult than any of these AC or DC systems.
