Old 02-27-2020, 01:44 PM   #1
slider door mods
So what exactly has to be done to a slider door Econoline to clear the tires with a 6" u-joint conversion? and how hard is it? do they sell a bracket extension kit?
Itchy feet is offline   Reply With Quote
Old 02-27-2020, 02:23 PM   #2
For the DIY'er
http://mgmetalworks.com/hinge.pdf
Old 02-27-2020, 02:25 PM   #3
Weld-tec Designs and Timberline Vans sell pre-made hinges.
Old 02-27-2020, 04:02 PM   #4
wow! Thanks for that that is an amazing wright up. I will check out the tailor made stuff and compare. Defiantly looks like it will take some fiddling. Your a legend.
Old 02-27-2020, 04:11 PM   #5
wow 400 to 475 for the hinges that a lot. will probably be doing the diy
Old 02-27-2020, 04:11 PM   #6
Glen's Avatar
My van has the slider & came with MG's adapter & it works great...
Friends Don't Let Friends Do Stupid Things Alone
Glen is offline   Reply With Quote
Old 02-28-2020, 08:52 AM   #7
REDOVAL's Avatar
Depending on your wheel/tire fitment you may only need a little bit. I extended mine 1" and it works fine on a 17x9 wheel (4.5bs with neg 12mm offset) and a 35x12.50-17 tire.
Scott
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 02-28-2020, 12:45 PM   #8
vandiesel's Avatar
Quadvan also has a hinge replacement that clears.
